Import Spline CSV script "no valid points"
Message 1 of 25
The ImportSplineCSV script keeps giving me an error message that says "No valid points." I've double checked the format of the csv file: it has about 20 points with X, Y, and Z coordinates and nothing else. Any ideas?
Replies (24)
Message 2 of 25
I have the same problem, any solution?
Message 3 of 25
amdx3H5YM6
Observer
Observer
me too...
Message 4 of 25
JeromeBriot
Attach the CSV file you try to import.
Message 5 of 25
steveCSNTC
File attached, i have the same issue
Message 6 of 25
steveCSNTC
i have the same issue. Test file attached.
Message 7 of 25
davebYYPCU
You need X Y and Z
Might help....
Message 8 of 25
jmpframce
even with z i get always invalid point
Message 9 of 25
Protective-foam_com
I have this same issue:
Below is the data format:
And the file in attachment
Message 10 of 25
HughesTooling
@Protective-foam_com  Think your problem might be using a comma rather than a point in your numbers and a semicolon rather than a comma as the separator.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 11 of 25
HughesTooling
@Protective-foam_com  I edited your file in notepad and replaced the commas with points and the semicolons with commas and it works. See attached file.
Mark Hughes
Message 12 of 25
Protective-foam_com
It works!
You were right, the semicolons were the reason:
Thank you very much for help!:)
Message 13 of 25
JeromeBriot
@jmpframce, @Protective-foam_com@HughesTooling
I wrote a new version of this script that should accept more CSV file.
See there: [Script] Import spline from any CSV file
Post comments on the thread above.
Message 14 of 25
smostini
I also have the same problem but despite replacing all the semicolons the file does not work.
I tried to install Girolamo Briot's plugin but it doesn't work.
I attach the file below.
Message 15 of 25
JeromeBriot
@smostini Remove all the periods from the file and try to load it again.
Message 16 of 25
mstannmarina
Community Visitor
Community Visitor
Hi!
I have the same problem with Fusion and .csv file import.
I also could not download your new version of the script, I don't understand why, but the Fusion 360 App doesn't see it...
I have attached my file to the message.
I would be very thankful if someone could tell me, how I can import this file!!
Message 17 of 25
davebYYPCU
3 data columns
X, Y, Z
Should work.
You have too many columns.
Might help,,,,
Message 18 of 25
memsmith1
Hello I've been having the same problem. I'm trying to import coordinates for a NACA 0009 aerofoil to be drawn on Fusion. Could I have some help please?
Message 19 of 25
JeromeBriot
Message 20 of 25
Protective-foam_com
Hello @JeromeBriot,
At the beginning, I wanted to thank you for your commitment to the development of the script.
I'm currently testing the new version of the script. Regarding the delimiter characters, everything works correctly, and the points are loading into Fusion properly.
Since I started using the script, I've had an issue with the scale.
Example:
In Excel, the coordinates of one of the points are as follows:
After loading the CSV file into the script, the coordinates of this point in Fusion are as follows:
I solve this problem by scaling it by a factor of 0.1:
Is it possible for the script to consider the scale factor when importing points?
I would like to add that in Fusion, I have the units set to mm.
best regards
Wojciech
