I'm trying to make a garage door track, but I can't assemble it correctly...
jonYDM8U
Message 1 of 8
jonYDM8U
This is driving me insane.
I have a garage door track.
In that track I have a wheel with an axle.
That track turns 90 degrees, but I can't seem to direct my wheel to follow the path of the track beyond a slider that is constrained to a single axis.  The wheel component will slide along the straight track, but as soon as the 90 degree 12" radius track is reached, it stops and won't follow the track.
I can get the wheel to slide back and forth in a straight track as a slider joint, but when it approaches the 90 degree turn, it just moves through it and continues on the same path.  If I create a contact set for the wheel to the track, when it gets to the 90 degree turn it just locks up.
How do I make a garage door that will open and close following the track path?
Replies (7)
Message 2 of 8
OceanHydroAU
If helps if you share your sketch so we can show you how to fix that (if it's not confidential).
Message 3 of 8
jonYDM8U
Good point.
https://a360.co/2WBKr61
Wasn't sure how to do that.
Message 4 of 8
ben6SY27
Observer
Observer
Hi @jonYDM8U  a long shot, but did you ever resolve this? I’m also trying to model a sliding garage door track.
Cheers, Ben
Message 5 of 8
jonYDM8U
I have not... :/.  But, I also stopped working on it.
Message 6 of 8
TheCADWhisperer
@ben6SY27
I suspect there is a technique in Fusion, but I would use Autodesk Inventor Professional >Dynamic Simulation for this.
Are you a student?
Message 7 of 8
ben6SY27
Observer
Observer
Thanks for the suggestion - unfortunately I’m not a student and can’t justify spending that much on a one-off job for my home.
I’ll try a few more things that I’ve seen people suggest with Fusion 360 before giving up 🙂
Message 8 of 8
ben6SY27
Observer
Observer
Thanks for the reply - I knew it was a long shot! 🙂
