I can't use parametric text
p_nicolasZKMWY
Message 1 of 8
p_nicolasZKMWY
Community Visitor
Community Visitor
Hi there,
I'm having an extremely frustrating issue, no matter what I do I cannot access parametric text.
This is a brand new part, on a fresh Fusion install, and you can see that I have no "text" unit:
On a  different PC, you can see that there is no "fx" shown or available in the text tool in a sketch:
I really need this feature for a class I'm teaching so I would greatly appreciate getting to the bottom of this issue.
Replies (7)
Message 2 of 8
HughesTooling
You are only able to access parameters to add to the text you entre in the text dialog.
So here I have a parameter Size and added it to the end of the text string between the single quotes. On the PC with no fx showing I'd guess you're in direct edit mode with no history\timeline? Without history enabled parameters are not avalible.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
g-andresen
The “Text” option must be available under “Add User Parameter”.
günther
Message 4 of 8
HughesTooling
günther
@g-andresen You're right. I looked alphabetically down the list and missed it being at the top.
Here added the parameter Text at the end.
Mark Hughes
Message 5 of 8
HughesTooling
@p_nicolasZKMWY Are you using a lab install of Fusion and how up to date is it?
Mark Hughes
Message 6 of 8
p_nicolasZKMWY
Community Visitor
Community Visitor
I think this could be the issue, my version is shown as "2601.0.90 x86_64"
What should it be?
Message 7 of 8
HughesTooling
What should it be?
Not sure but Parametric Text was introduced in September so I guess what you're using is quite out of date.
After a bit of Googling looks like the latest lad version is 2702.1.58.
Mark Hughes
Message 8 of 8
lauri_barnhart
@p_nicolasZKMWY - Welcome! Thanks for your question.
Did previous replies by @HughesTooling and @g-andresen help clarity your question?
If this fixes the issue, please go ahead and accept it as the solution.
This ensures others can benefit from the resolution shared here.
If the issue persists, let us know with an update so we can assist further.
Best,
Lauri | Community Manager
