How to delete a Fusion Team?
TeamContra
TeamContra
Long story short I created a Fusion team with a placeholder name as a test. Afterwards learned that I can only create one Fusion team, so I figured let's delete the original team and create the proper one!
Nope.
Is there a way to do this in 2024? All I can find are years old posts on this forum full of people asking for this simple, basic feature, hopefully this has been implemented by now otherwise it seems like cancelling the account and buying SolidWorks might be the only solution....
vinayak_dhame
Hello @TeamContra,
We are sorry to hear you are having trouble with the Fusion team created using a placeholder name.
You are right that we can create only one Fusion team per user, and it is difficult to delete it once created.
We recommend that you can change the name of the team that you have created.
Below is the link to change the Team Hub name:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-change-Fusi...
Let us know if this helps.
Best Regards,
Vinayak Dhame
Vinayak Dhame
Autodesk Fusion
