How to Create a Sphere from a Circle on a Sketch?
How would I create a sphere from a circle on a sketch. Let's say that I start (in a sketch) with a large rectangle and then put a circle in the center. I would like to revolve the circle into a sphere and extrude the remainder into a thin surface. So the result should look a little like a card bisecting a marble.
Thanks for any assistance!
John
jhackney1972
The first thing you need to know is that you cannot create a sphere from a circle.  You will be using the Revolve command on a semi-circle.  Fusion 360 has a Sphere command which creates a sphere directly without a sketch if you want to use that.  Take a look at my screencast for the process you asked for.
John Hackney, Retired
Thanks!
The semi-circle was the missing piece I needed. That was a terrific video.
Appreciate all your assistance!
John
gyalemon
Thanks! I really appreciate that you took your time to make a screencast. It's so much easier for us beginners to understand what you're doing.
oo7_golden_1
@jhackney1972 I know that you posted this many years ago, but I just wanted to log into the forums and say Thank You for demonstrating how to make a sphere from a sketch in Fusion 360.  I used your method to easily cut a sphere out of an object on one of my projects and I was able to complete the cut exactly where I needed to.
Thanks again for sharing your knowledge with the community.
Sincerely,
Brian B.
illegallyalive
Community Visitor
Community Visitor
This is so helpful!! Thank you for taking the time to make it!!
