How to change material for part
ElectronicsNut
Message 1 of 17
ElectronicsNut
My official first post. I am trying to change the material properties from steel to Plastic ABS. I select "Modify", "Physical Material", "Plastic", and when I mouse over ABS I get a hand and cannot select it. Is there another way to change the Materials Properties? Sorry, I posted to the wrong section.
Replies (16)
Message 2 of 17
SolubleSpork
In order to change the physical material on your part, I believe you have to click and drag the material you want (in this case, ABS) to your part.  Just clicking on the material doesn't do anything.  You can also access the "physical material" dialog by right clicking on the body or component in the tree.
Message 3 of 17
ElectronicsNut
Thank you very much... worked perfectly
Don
Message 4 of 17
SolubleSpork
 Glad I could help.  Welcome to the forums.
Message 5 of 17
thanks very useful
Message 6 of 17
wingedalpha
Observer
Observer
Has this changed since 2018? no matter how much I try to change the appearance of the part, it still shows up as steel in the parts list of the assembly drawing I'm working on.
Message 7 of 17
TheCADWhisperer
@wingedalpha
Materials (properties) and Appearances are two different things.
Message 8 of 17
wingedalpha
Observer
Observer
Here it is. I'm trying to make it aluminum
Message 9 of 17
crofton_murray
Observer
Observer
I can't find the 'modify' section to change the material.
Message 10 of 17
TheCADWhisperer
@crofton_murray
Show screenshots of what you see - something like these...
and if you want to create a custom material...
Message 11 of 17
crofton_murray
Observer
Observer
Thank You.
Message 12 of 17
crofton_murray
Observer
Observer
I was trying to model some bullets, and I couldn't make it with the right materials on fusion.
Message 13 of 17
crofton_murray
Observer
Observer
This is what it looks like:
Message 14 of 17
TheCADWhisperer
@crofton_murray
It appears that you have Surface Bodies rather than Solid Bodies.
Also, you are not showing the Materials in your browser.
And, there is an unresolved issue highlighted in your Timeline.
Move is almost always the wrong move as used by beginners.
Message 15 of 17
TheCADWhisperer
@crofton_murray
Did you figure this out?
Message 16 of 17
crofton_murray
Observer
Observer
Here is the file:
ps, I am in yr 7.
Message 17 of 17
crofton_murray
Observer
Observer
The main bodies of the bullets are made of brass, the top of the slug is made of steel, and the top of the other bullet is made of copper.
