How to change date into normal format ?
naudin
Message 1 of 12
naudin
The date displayed below my parts is bit weird, it shows dates like 5/26/21
How can I fix it?
Replies (11)
Message 2 of 12
TheCADWhisperer
What is “normal format” for you?
Are you on Windows or are you on a Mac OS?
Message 3 of 12
a.reissig
Hi Naudin and CADwisperer,
The standard in fusion is MM/DD/YYYY
here in europe almost no one uses this format.
DD.MM.YYYY or YYYY-MM-DD is a lot more common.
https://en.wikipedia.org/wiki/Date_format_by_country
Can you switch Date format?
Thanks in advance Alexander
Message 4 of 12
naudin
DD/MM/YYYY or YYYY/MM/DD
I'm on Windows
Message 5 of 12
TheCADWhisperer
I am pretty sure that the date format is harvested from the OS.
If I change my OS it changes in Fusion 360...
(I am using Windows 10 OS)
Message 6 of 12
naudin
My OS is in dd/mm/yyyy
Message 7 of 12
a.reissig
My system is DD.MM.YYYY
Im using Win10.
for a Test i switched to YYYY-MM-DD but nothing changed in fusion.
My System is also using 24:00 clock and Fusion is using am/pm. 😑
Message 8 of 12
TheCADWhisperer
Where are you referring to a date in Fusion?
In a Drawing?
Can you show screen capture of the reference?
Message 9 of 12
a.reissig
in the data folder structure
Message 10 of 12
ImDaveM
I have just noticed this problem too, the date is display in USA format, the rest of the world shows there date in the proper logical order
Message 11 of 12
matko.ribicic
Hi all,
I wanted to let you know that we recently upgraded Fusion so now it matches the date format of your computer's operating system.
The created date in a new drawing also reflects the date format settings of your OS.
E.g.:
Matko Ribicic
Product Manager | Fusion Data
Message 12 of 12
a.reissig
Thanks!!!
That works a lot better for my european brain.
