How do you cutout a angle in 3d extrusion?
digitalhomeserviceswa
Message 1 of 8
Hi all, I'm having trouble cutting out an angled shape in a 3d extrusion. I created a shape in the sketch (3d) that has an angle and then performed an extrusion. Now on that angle that's now a 3d block, I want to again create an angle that I want to cutout of the 3d block. I place a new ketch plane where I want to draw the angle and then extrude (cutout) on that plane but each time I do so it's not following my angle. It always cuts out at  90 degrees from the drawn line.
I'm stuck. Hope someone can help me.
Replies (7)
Message 2 of 8
davebYYPCU
Need a file, pic or movie to understand your problem.
Message 3 of 8
Hi all please see images below hope that helps to understand what I'm after. Cheers
Message 4 of 8
davebYYPCU
Use the Sweep Tool.
Profile to cut is the triangle you have selected already.
Path is the blue line, but it can not be a construction line, change it to Normal Line.
Might help....
Message 5 of 8
Sweeping tool! Awesome Dave but still got an issue at the bottom where it won't cutout. Any ideas?
Message 6 of 8
I figured it out mate. I had to create another sketch plane and draw another line and do another sweep to continue the cutout. Cheers mate much appreciate it.
Message 7 of 8
here's my final image with the completed cutout.
Message 8 of 8
davebYYPCU
Or the Path line was too high, and should be longer, to cover the complete cut.
Might help...
