How do I turn object snap on?
適用対象外
44,658件の閲覧回数
19件の返信
メッセージ1/20
適用対象外
I have been trying to find where to turn object snaps on in fusion 360. I have used many CAD software before like AutoCAD, Solidworks, MasterCAM, and Rhino and all of them have the ability to snap to places like center points in circles and intersections between objects but I cannot find these options anywhere in fusion 360. Can anyone help me?
0 件のいいね
解決済み
44,659件の閲覧回数
19件の返信
返信 (19)
メッセージ2/20
jhackney1972
I assume you are talking about sketch constraints which are sometimes called "object snaps" in other applications.  These are applied automatically while sketching in Fusion 360.  You will notice then appear when you get near a circle center, sketch a vertical or horizontal line.  You may not be seeing them after they are placed because you do not have "Show Constraints" checked in the Sketch Palette.
Additional sketch constraints can be added by selecting them from the "Constraints" tool panel.  In the screen capture below I am showing you the new UI Preview Fusion 360 environment.
You can prevent a sketch constraint from being automatically applied by holding down the Ctrl key when you are picking points in your sketch.
John Hackney, Retired
メッセージ3/20
g-andresen
解決済み
If I understand you correctly, you're looking for the projection tool.
This is selected in sketch mode with the shortcut "P" or in the sketch palette under Project.
In the preferences you can activate "autoproject“.
günther
メッセージ4/20
plouciplouca
Community Visitor
Community Visitor
A big thanks to you ! I was looking for the answer about "why my snap do not work at all?" and found nothing but your answer. Now that ghosty box is checked, my snap definitely works now !
0 件のいいね
メッセージ5/20
mhag33tg2
I am trying to draw a sketch on a plane that is a section through other existing components. I want the sketch for the new component to be drawn exactly and relative to several other existing components.   But I can't get the sketch lines to snap to the lines and features of the existing components in that cross section.  I have seen in the training video  (  https://help.autodesk.com/view/fusion360/ENU/courses/AP-SKETCH-BASICS  at 1min 43 sec.  ) it is possible and normal to do, but I can't get lines to snap to objects like James does.   My new sketch lines do sometimes snap to other objects at other times, eg like when sketching on a surface, but for me how and when snaps work and do not work seems pretty random, meaning I do not understand it.
In my section plane the sketch lines will snap to the grid, which is not what I want.   In the sketch pallet I turned that off.  I have tried various sketch pallet settings to no avail. The above replies do not help.  I presume something is wrong with my snap settings and have tried to find how to change it in Fusion (like in AutoCad), but I can't see how to do that.
To get the section plane I am working on, I did this:   >Solid>Construct>Plane...   then  Inspect>Section Analysis> and selected that new plane.  Then  Solid>Create sketch>Select that construction plane.    I have also tried the nice "slice" functionality in the sketch pallet, but the object snaps do not work in that for me either.
I would appreciate your help.
0 件のいいね
メッセージ6/20
cow448w
youll probably find as time goes by and these poxy updates are installed you loose functionality in this crap product. i wish to god id never bought it!
メッセージ7/20
TheCADWhisperer
You can test for free before purchase?
0 件のいいね
メッセージ8/20
mhag33tg2
I found out how to make snaps work.  Software did not need an update.  There is a setting in preferences that needed to be turned on.  My first project was a struggle with the very steep learning curve but now I am onto my third project and am speeding up, making fewer mistakes and getting good progress.
0 件のいいね
メッセージ9/20
samehbijo
I am having the same issue , which settings in preferences exactly that fixed your problem ?
0 件のいいね
メッセージ10/20
mhag33tg2
I can't remember exactly now, but I think do this:   Click your initials in top right corner, click preferences, click Design under General, turn on the check box for either "Auto project geometry on active sketch plane" or else it was  "Auto project edges on reference".   I recall there was a check box in there that was off and it just needed to be turned on to make snaps work.
メッセージ11/20
適用対象外
Go to Preferences (From top-right corner)
Open General>Design
Check "Auto project edges on reference"
(These are how my settings settings look like)
This worked for me, I hope it will work for you as well 🙂
メッセージ12/20
samehbijo
Thanks alot , it does work , however , on every click I do , a projection line and constrains are created , I wish that there is a way jut to use the snaps without the projection lines .
0 件のいいね
メッセージ13/20
g-andresen
my tip:
uncheck the setting in preferences and use „project“ tool (P).
This way it´s your decision.
günther
メッセージ14/20
rimell
Observer
Observer
Where exactly is that setting in preferences? Can't find it!
0 件のいいね
メッセージ15/20
g-andresen
here
günther
メッセージ16/20
TheCADWhisperer
Are you looking for Preferences or the setting?
0 件のいいね
メッセージ17/20
fireflynj
Did not work for me.
0 件のいいね
メッセージ18/20
TheCADWhisperer
@fireflynj
What didn’t work for you?
0 件のいいね
メッセージ19/20
fireflynj
'Auto project edges on reference' did not work, but using the 'P'  I got many points and triangles that I could click on, but no lines.  Turns out it was because the body was converted from a STL file.
0 件のいいね
メッセージ20/20
bshoekstra
Observer
Observer
This worked for me.  Thank you!  🙂
0 件のいいね
