Text in "User Parameters dropdown list" is unreadable/ghosting (HiDPI display)
vojnar
vojnar
I have problems with HiDPI settings for Windows 10 (Performance Tips for running Fusion 360 on high resolution monitor). My system is Surface Book with Performance base (i7 cpu, 16GB memory, NVIDIA GeForce GTX 965M). All works reasonably good, but when I start to input my "User Parameters" then the problem appears. The dropdown list text is hardly readable mindf*ck (text is ghosting):fusion360_ghosting.PNG
This problem appears only in dropdown menu while entering text to find User Parameters. Standard dropdown menus (input history) in tool forms are ok and looks normal but differently:fusion360_ok.PNG
Where is the problem? Can I do somethoing or must wait for bugfix?
Best regards
Jan Vojnar
ryan.bales
Autodesk Support
Autodesk Support
The fixes in that article are intended to fix the problem. In newer windows 10 versions there is an option to let applications decide scaling.
Ryan Bales
Fusion 360 Product Support
vojnar
That ghosting started to happen after I set "High DPI scaling behavior "to perform scaling by "Application". When scaling behavior hasn't been overriden the Fusion 360 works normally but pixelled/blured and slow but everything works.
ryan.bales
Autodesk Support
Autodesk Support
Hmm i did not grasp that from the first response, thanks for the clarification.
Ryan Bales
