How can I hollow this body?
Message 1 of 11
So I got well into creating a football helmet shell by starting with a quadball. I need to hollow the body so that the shell has a 3mm thickness, but the function isn't working as I expected. You'll be able to see in the attachment that I partially achieved it, but can't figure out what I need to do to get the whole body to hollow to the 3mm thickness I'm looking for.
Can anyone give me any guidance on this one? Did I miss a step somewhere?
Replies (10)
Message 2 of 11
g-andresen
Hi Christopher,
The principle could be like this:
how to hollow somethinghow to hollow something
Then all you have to do is get your head in it.
günther
Message 3 of 11
HughesTooling
Is this closer to what you want? See attached File. Also do yourself a favour and do some of the hands on exercises in the help. Extrude does the job a lot better than split body.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 11
davebYYPCU
Shell straight after the Quad ball, and before cutting any shapes or holes,
Might help....
Message 5 of 11
Thank you! I'm going to practice what you showed me there so I can get it down pat. And yes, clearly have more work to do their to get the head in, lol. Thanks again!
Message 6 of 11
Yeah that's great. Would you be willing to tell me why extrude is a better process? I took several Autodesk tutorials and they showed me both ways. But I'm not sure I'm understanding why one would be better than the other. Thanks!
Message 7 of 11
HughesTooling
In this case if you use extrude cut you're not left with the extra bodies. I'm assuming the 2 extra bodies in your version using split were not needed.
Mark
Mark Hughes
Message 8 of 11
Ok, but isn't that just a matter of right-clicking and deleting the extra body?
Message 9 of 11
HughesTooling
Did you try that? If you ever get into making bigger designs you want an efficient timeline so removing what you don't want with one extrude is better than 2 splits then 2 removes.
Mark
Mark Hughes
Message 10 of 11
Ok, will use extrudes going forward. Thanks Mark.
Message 11 of 11
xmasbad
Thank you sir
