How can I export *.dwg include scale?
pixelfriend
Observer Observer
pixelfriend
Observer
Observer
I will plan to a request to metal work.
And they ask you to send it as a *. dwg with the scale of sketch.
But the scale of the sketch is not included when I tried.
How can I handle it? Please let me know.
g-andresen
1. save sketch (1:1) as DXF
2. open in Autocad, QCAD ... save as DWG
3. use online converter DXF/DWG
günther
pixelfriend
Observer
Observer
Can you explain a little bit more detail?
g-andresen
1. I assume that Metal Worker needs 1:1 data.
2. 1:1 data can be found in sketches of the design mode.
3. right click on the sketch > save as DXF
4. open in ACAD, QCAD and save as DWG
or
5. convert DXF to DWG via an online converter.
6. result: 1:1 data in DWG format
günther
ClintBrown3D
Hi @pixelfriend
If you are looking to export a 2D drawing to DWG with scale, this is the workflow:
By double-clicking on the view, I was able to see that the current scale is 1:4. I then exported the drawing to a Simplified DWG format.
Hope this helps.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
