Produt Design extension - Plastic rules unit issue BUG REPORT
electronic_lichens
electronic_lichens
I created a new plastic rules and it keep switching as soon as i save it but not on all the spec.
I put everything in mm but if i open the rule again, the thickness range, thickness and sometime the knif edge thresold goes back to inches.
It's really annoying when using the analyse feature as everything will then come up in inches. i tried with another rules that stayed in mm and it worked no problem with the analyse feature displaying value in mm.
It's on the same design, same part. Design is set in mm.
Phil.E
I cannot reproduce the bug. I created a mm design and a new mm based rule. I applied the rule and saved the design. All my rule settings remain as mm.
Could you possibly share a design that has this problem, and specific steps to repeat it? I'm glad to investigate and report it to development, but I can't do that without a reproducing case.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
