How can i change this Detail?
tom.frankee1991
Message 1 of 13
tom.frankee1991
Hey guys,
I’d like to change a small detail on this shape — specifically, the dent at the bottom part of the form. It should just continue in a regular rounded way. It seems so simple, but after several attempts, I can’t figure out the solution. When I try to balance out the dent at the bottom using another target body, it tends to intrude into the upper indentations see second screenshot). Can someone do a short screencast or using my fusion file above, so i can check how its done. Ive used two "U" shaped bodys and combine them together.
Thank you so much
Tom
Replies (12)
Message 2 of 13
TheCADWhisperer
@tom.frankee1991
Are you willing to start over from scratch?
Do you have a picture of something similar from the real world that illustrates where you are going with this design?
Are you sure that you want no gap here?
My wild guess...
Message 3 of 13
davebYYPCU
Total guess at this stage, what I think you want.
Might help..
Message 4 of 13
tom.frankee1991
@davebYYPCU
Thank you
that helped me a lot!
@TheCADWhisperer
Yeah there is supposed to be a gap, my model was just a trial.
How did  you made hollow the body? If iam using the hollow tool, it gives me an error notification
Message 5 of 13
TheCADWhisperer
@tom.frankee1991
You have accepted a solution that is all wrong.
As stated by @davebYYPCU It was just a guess to try to get an idea where you wanted to go with this.
Do you want to learn how to do this correctly?
In the "solution" that you accepted the sketches were not fully defined - the "solution" will fall apart with any edits.
Your sketches were not created using the Slot command - the most efficient technique.
I think you are reinforcing poor modeling techniques.
Message 6 of 13
TheCADWhisperer
@tom.frankee1991 wrote:
... my model was just a trial.
@tom.frankee1991
Are you ready to start over from scratch to learn to do this correctly?
Message 7 of 13
tom.frankee1991
Sure!
A Screencast Video would be helpful
Message 8 of 13
TheCADWhisperer
@tom.frankee1991
How much of a gap do you want?
Step 1. Sketch a 2-Point Rectangle with upper corner at the Origin and going down to the right.
Dimension as shown...
Click on image above to enlarge the view.
Message 9 of 13
tom.frankee1991
A GAp of 2mm is fine
Message 10 of 13
TheCADWhisperer
@tom.frankee1991
I am going to make a video on the modeling process.  I made a mistake on my initial attempt that I need to correct so that the model will edit without errors.
It will probably be tomorrow before I can post the video.
Message 11 of 13
TheCADWhisperer
Sure!
@tom.frankee1991
Here you go...
(view in My Videos)
Message 12 of 13
tom.frankee1991
Thank you so much for this screencast!!
Beside of the actual matter, ive learnt lot of other details in your video which i will adapt!
May i ask why you would never mirror in a sketch?
Message 13 of 13
TheCADWhisperer
@tom.frankee1991
Rarely, not never.
In my experience sketch mirror seems to be more computationally expensive and less robust.
Frankly, I got lazy - if this were my work I would have duplicated the rectangle and fillets on the other side rather than mirror.
Bottom line intent of the video though - always fully define your sketches.
Still curious where you are going with this as I suspect I might model differently if I knew the ultimate Design Intent.
Like @davebYYPCU I was just making a wild guess.
