How can I change the modus from working in the mesh body mode back to the volumina body
Monika-Blanka-Katterwe
Observer Observer
Message 1 of 8
Observer
Observer
How can I change the modus from working in the mesh body mode back to the volumina body that I can create a hollow body with drillings how I normaly works on. Please excuse, maybe it is the solution simple. I am a beginner here at Fusion or better saysed a self learning creator and happy if somebody there who are interested to help.
Kind regards
Monika
Replies (7)
Message 2 of 8
g-andresen
If you have created the body yourself in Fusion, go back in the timeline and edit the solid.
Please share the file.
File > export > save as f3d on local drive  > attach to post.
günther
Message 3 of 8
jeff_strater
It is possible that all you need to do is click on the "Exit Form" button in the upper left.  But, more info (images, video, model) is needed to answer definitively
Jeff Strater
Engineering Director
Message 4 of 8
TrippyLighting
@Monika-Blanka-Katterwe As others have already mentioned, please share your design in .f3d format.
I looked at your website, or at least I believe so. Your name is fairly unique 😉
I'd love to hear what you want to design and the purpose behind it!
The refractive caustics and dispersion have me captured!
Message 5 of 8
Observer
Observer
 @jeff_strater
Dear Jeff Strater, thank you very much for your fast answer, but it dosn't work so easely. I have include the picture of the object and the report what is wrong. My problem is to make it in common with the hints because I havent so much experiences. Maybe it is someone here who would like to help me learn to make it better that all it works correct.
kind regards
Monika
Message 6 of 8
Observer
Observer
Dear Jeff Strater,
thank you very much for the tip how it can be works, but unfortunalely this easy way don't work.
Maybe you can help me step by step to work this interessting scape correctly.
Kind regards
Monika
Message 7 of 8
Observer
Observer
Dear Peter Doering,
thank you very much for your kindly feedback. Here you can find the object, but trying to rendering or to export in other formats does not work easely.
Maybe you can give me some hints.
Kind regards
Message 8 of 8
jeff_strater
Thanks, @Monika-Blanka-Katterwe - can you share your model here?  Export as a Fusion Archive and attach it to a reply here.  It looks like your Form (T-Splines) body has some errors.  It is possible that you may be able to fix those errors.
Jeff Strater
