DXF export blocked
DXF export blocked
odolyte
DXF export blocked
odolyte
It seems that since the last update, i can no longuer export sketches as DXF.
As soon as i try to put a name for the file, i have a warning about using special caracters (wich i don't). This prevent me from saving the file.
I'm Working on a Mac M1 under Sonoma last version.
Moebius Factory
odolyte
Addition : In fact, it seams that any file export is blocked by this bug. We have to go to autodesk 360 online to be able to download files.
Moebius Factory
Warmingup1953
No problem here. Keyboard issue? Uncheck save to Computer?
odolyte
When unchecking "save to my computer" the warning disapear, but the problem is still intact when i want to save the file on my computer 😁.
I've tried with external keyboard. Same issue 😟
Moebius Factory
HughesTooling
Is one of the blocked characters in the path you're trying to save to? Do you still have a problem saving to a different directory? Also do you still have the problem after closing then restarting Fusion?
Mark Hughes
Owner, Hughes Tooling
odolyte
I changed the path then return to the same folder i was in before (i have no special caracters in my folder names except "-" between words) and it worked. Strange but it worked ! Problem solved.
Thanks @HughesTooling !
Moebius Factory
