Home button disables data panle button.
markTJ62F
Observer Observer
Message 1 of 8
markTJ62F
Observer
Observer
When I click the home button on the upper left side of the screen it disables the data panel button. Is it just me doing something wrong and or my computer?
I can work around, i just liked to be able to switch between the two.
Replies (7)
Message 2 of 8
lance.carocci
That's expected. The Data Panel is only active in a document context, so is disabled when a document is inactive.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 3 of 8
jccoyle
the data panel navigates the project tree, not the open document. no reason it can't still function without a document open, particularly since it appears to show data the home view does not (document versions)
Message 4 of 8
TrippyLighting
@jccoyle, please see this thread.
Message 5 of 8
lance.carocci
Ultimately, the reason is because Home is intended to be the primary project navigation method rather than Data Panel.
Lance Carocci
Message 6 of 8
jccoyle
That's an idea I guess. I spend most of my time with a part open navigating projects with the data panel. If I close the last document I lose my place because the data panel goes away and I get kicked back to the home panel, which I only use to open the first document in the session so I can get back to the data panel. If you want us to land on home when initially opening the software that's fine, but locking us out of the data panel even though it should, by all rights, be totally funtional in the absence of an open document, in order to guide us to the navigation method your design team prefers rather than the one I spend 98% of my time in is fairly annoying.
Message 7 of 8
rosie_lucas1
Hello @markTJ62F,
Did the information provided by @lance.carocci help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
Message 8 of 8
gtprototype
Why is it when the delevopers disrupt our work flow, the answer is "it's designed to work that way".  Are they testing our resolve to stay with Fusion?
Dale Speakes
prototype technology
