Hole propagation in a pattern
micromelt01
micromelt01
I have a group of jointed components. I create a hole on the middle component and attempt to apply a pattern across all of the components that share a plane. The holes only propagate across the middle component and not the adjacent ones. I am working with the top level activated.
Any suggestions welcomed.
jeff_strater
This is a current limitation of all the feature/face pattern commands - they only work if the target is a single body, so you cannot pattern holes across multiple components or even bodies within the same component.
Jeff Strater
Engineering Director
micromelt01
Thanks for the info.
I hope this feature is on your 'things to do' list.
regards,
David Taylor
micromelt01
Hi Jeff
I have read your explanation again and I must admit to not fully understanding.
I created a hole which went through one component and two attached bodies and then also through another component and 2 attached bodies; 6 bodies in all. Then I propagated the hole and it was copied through all 6 bodies in 4 positions so I have, it seems to me, patterned holes across multiple components and bodies within the same component.
So it appears to work on components 'further away' but not 'next door'.
regards,
David
jeff_strater
good question.  Understand why this may be confusing.  The short answer is:  Hole supports cross-body/cross-component targets, but Pattern does not.  You can see this in the screencast below.
The reasons why are internal and a bit complex.  When you create a Hole through 3 components, there are actually 3 Hole features created behind the scenes - one for each component.  These are all represented in the Timeline as a single Hole feature, but there are actually 3 of them.  This is mainly done so you can do Save Copy As on a component, and bring all its features along.  When you do a pattern of that Hole, we are replicating all 3 features.  But, as you see in the screencast below, that pattern will not propagate to components or bodies that were not part of the original Hole.
Jeff Strater
