Hole command issue
Hole command issue
Reno_Raines01
Hole command issue
Reno_Raines01
having an issue with the hole command, when I select multiple locations for holes from a sketch the holes do not properly compute, there is a thin layer on top remaining. When I do a single hole using 'at point' there is no issue and the hole properly computes.
I sometimes have this issue too with extrude/cutting sketch gemeometry, a thin layer is remaining.
Screencast:
g-andresen
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
