Having Trouble With Fusion 360 and ClickLock
daudirsch
Observer Observer
daudirsch
Observer
Observer
There is a feature in Windows called "ClickLock".  It allows those of us with a disability, who have trouble using a traditional mouse, to be able to click-and-drag to select items.  For me, I use a mouthstick to do all my work and cannot press a button and move a mouse at the same time (I am paralyzed from the chest down and can't use my hands).  ClickLock allows me to press and hold the left mouse button (for a moment) and then I can move the mouse and it will click-and-drag for me.
All of that to say, Fusion 360 does not seem to recognize the ClickLock feature on Windows.  I can shift+click items to select them, but I can't click-and-drag to select items.  It becomes a big issue when I need to select many small items that are almost impossible to select one at a time.
I verified that all of the Select filters were on.  I tested turning ClickLock off and had someone else click-and-drag and it worked fine.
I realize this is kind of a weird situation, but I was just curious if anyone had a suggestion for a workaround for something like this.
jhackney1972
I can see where this feature would be very help for you.  I found a workaround that may or may not help you as the initial mouse click, to activate the Click Lock feature, must be combined with a slight mouse movement.  The video will illustrate.  During the video I try and make it clear when I am not holding down the mouse left button as you can see my hand.
(view in My Videos)
John Hackney, Retired
daudirsch
Observer
Observer
Thank you for your detailed response.  You have outlined the problem very eloquently.  I can confirm that it does indeed "work" if you move the mouse while clicking (I had someone try it for me).  Unfortunately, no matter how short I make the click time, it doesn't work for me as I cannot physically do the 2 operations simultaneously.
Even though this is a big issue, anything that requires clicking and dragging does not work in Fusion 360 with ClickLock turned on.  There are several things I can enter manually (like measurements and dimensions)  but other things don't have a workaround like moving nodes in a sketch, etc.
This is the first CAD system I've used with this issue, but I really like the product.  "Hey, AutoDesk, I'll be a tester for any future accessibility features!!"  🙂
