Grid does not auto adjust
riodesignltd
Message 1 of 9
riodesignltd
I saw a post similar to this, where the layout grid would not auto-adjust, although the issue there was due to a file type being used. I see this issue all the time. I am using the latest version of Fusion 360 on Win 10
I'm a semi-beginner to Fusion 360...but have used various CAD programs before, so I'm familiar with the work environment and 3d interface
I too see that my layout grid does not auto adjust...ever...right from the time i open the program to create a sketch...to extruding , etc. See my screen captures..
I have tried setting grid options to fixed...no change and to adaptive...no change. I scroll (zoom) in and out layout grid stay the same.
It's not a huge deal, but when I view tutorials and YouTube videos, well it's working for everyone else. I have tried setting all my parameters to default?? Is there a switch or view I've failed to turn on...or off.
John
Accepted solutions (3)
Replies (8)
Message 2 of 9
jhackney1972
There are two Adaptive Grid settings to make it work.  Take a look at the Screencast and make sure you have both of them set to Adaptive.
John Hackney, Retired
Message 3 of 9
riodesignltd
Hi John,
Thanks for the quik reply. I looked at your screencast...then checked my settings. I have both turned on to adaptive. But it still seems to me that the layout grid is in a fixed position...OR maybe it's me!
Meaning...I recall, with an earlier version of Fusion 360 (like last year) that the grid extended in all X/Y directions and it filled the viewport/display...rather than applying the grid and displaying it as my screen capture shows.
In other 3D programs I've used, Lightwave, 3D max, Blender, the grid fills the entire workspace/world.
Plus in UTube tuts...I see other users with the grid filling the display...
Thanks again
John
Message 4 of 9
TheCADWhisperer
Can you File>Export and then Attach a *.f3d file here that exhibits this behavior?
What happens if you turn the mouse wheel to zoom in - then what happens?
Message 5 of 9
riodesignltd
Hi Wisperer,
I created a new example and attached the files you requested. When I zoom with wheel, the view gets larger/closer, but I don't see any  auto-adjusting...do you??
john
Message 6 of 9
TheCADWhisperer
I did not see any sketches in the two files that you Attached here?
Message 7 of 9
riodesignltd
I had done them with a cube body...
I'll attach same with just a sketch...
J.
Message 8 of 9
TheCADWhisperer
Works fine here.
Create a Screencast Recording of the behavior that you observe on your machine.
Message 9 of 9
riodesignltd
Thanks...
I guess it's just the way it works.
Time to move on and get CAD'ng...
Appreciate the help from all
J.
