Fusion360 - ExactFlat upload eror
I am using the ExactFlat add-in to select peices to flatten. I click up load and enter my login information and I get the attached photo error message.error-message-6-12.JPG
This is causing me major issues as I am holding up production..of course....
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Just to check - does this happen upon uploading a single file - or does it happen to any file you try to upload? Also, does the error message occur after your type in your credentials? I am trying to see where the problem may lie. Unfortunately, Exact Flat is not an add-in that Autodesk produces so troubleshooting this may be a bit tough for me. One thing we can try is to cleanly uninstall the add-in and reinstall it, just to rule out a corrupt installation. I would only recommend this if this error is happening across all files. If it is unique to one file - this probably will not help and we should loop in the Exact Flat support team as well.
To cleanly uninstall your Add-In, please follow the instructions in this guide here.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
First off,
thank you so much for the rapid response!
So it fails for all files. I will try to reinstall per your instructions
The upload I was trying to do is one piece (very simple compared to what I usually do)
thanks again James I will  keep you posted.
If this doesn't work I will open up a ticket with ExactFlat (they are also usually very responsive)
-Joe
