Fusion stuck on white screen during starting. Im usina a AMD + Ryzen Hackintosh.
Message 1 of 28
Im usina a AMD + Ryzen Hackintosh. Fusion was working until now. I tried uninstalling and reinstalling. Did do any change.
Replies (27)
Message 2 of 28
Yep me too...
Bugger it.
I suppose its zero support with our machines.
Colin
Message 3 of 28
Whats your spec ? and Which OS ?
This is mine, Catalina 10.15.4
CPU
Amd Ryzen 7 3700X 3rd Generation Desktop Processor With Wraith Prism Cooling Solution (8 Core, Up To 4.4 GHz, AM4 Socket, 36MB Cache)
MOBO
Gigabyte X570 Aorus Pro Motherboard (Amd Socket AM4/Ryzen Series CPU/Max 128GB DDR4 4400MHz Memory)
Graphics
Sapphire Radeon RX 5700 XT Pulse OC 8GB GDDR6 256-bit Gaming Graphics Card
Please let me know if u get a solution. Im hoping next fusion update will resolve it. Im checking daily.
Message 4 of 28
Hi
This is mine, Catalina 10.15.3
CPU Amd Ryzen 9 3900X 3rd Generation Desktop Processor (12 Core, Up To 4.4 GHz, AM4 Socket, 36MB Cache)
MPG X570 Gaming Edge wifi.
Graphics Radeon RX570 OC 4GB Gaming Graphics Card.
My Fusion stopped running on my machine the update before the last. (about 2-3 weeks ago).
I am hoping as you are, that on the next update it is fixed.
I have looked through all of the startup logs and all is running right close to completing start up. It is failing on opening up the final window is what I can work out, so I think It may be graphics related (good to see you have a different graphic card than mine). All of the connection log is good.
Let's see. I am running Fusion on windows on the same machine and all goes good, so may not be graphic board but how OS uses that board. I don’t know.
Regards
Message 5 of 28
Newer version came, but its still the same.
Message 6 of 28
HI,
Had any luck in fixing this …..?
Colin
Message 7 of 28
I spoke to Fusion n Paul Sohi via insta, Fusion told they will try to help me out, Paul after some research told me ‘he thinks it’s hopeless’.
U there in insta? Pls contact @Anonymous
Message 8 of 28
Did you send him any error logs.
Message 9 of 28
  1. Nope, I was waiting for them to ask, but before that they were like Hackintosh is not an official apple product, so they can’t help.
Message 10 of 28
Thought as much …
CW
Message 11 of 28
I suppose u don’t know any other hackintosh user using fusion, right. I had enquired in discord groups, no hope.
Message 12 of 28
No I don’t but it is a good idea ….
Might look around
CW
Message 13 of 28
Found a guy who didn't face issue with fusion,
He uses cpu: ryzen 3400G, rx 580
Message 14 of 28
Are you Clover or Open Core?
I wonder what he was using?
Colin
Message 15 of 28
OpenCore
Message 16 of 28
Me Too.
May make a seperate boot disk using clover and install 360 onto that to se if that works,
I did an Open core running Sierra and 360 did not run on that either on this machine.
Before I try that can you find out what he used.
Thanks Colin
Message 17 of 28
Since the latest update, Fusion 360 takes more than 10 minutes to start on my computer (Intel [email protected], 16GB RAM, windows 10). Initially I thought it was totally stuck, so I did a complete uninstall (using the cleaner tool) and then reinstalled it. That didn't help anything. Then I decided to give it some more time and behold, after 10-15 minutes it actually started and was working fine...
Message 18 of 28
Got fusion working, steps as follows:
1) Clean install macOS, don’t sign in using Apple ID while installing or use TimeMachine backup. Both brings with it some files which doesn’t let fusion work.
2) Install Fusion.
Message 19 of 28
Lucky You.
I was so excited last night when you posted this.
Been woking on this for the past 3 hrs.
:(:(:(. No luck.
Good that you got it going.
Did you update to 10.15.5?
Did you use Opencore of Clover this time
Colin
Message 20 of 28
I had always use OPENCORE. Current one is 0.5.9 OC n 10.15.5 macOS.
Did u do a clean macOS reinstallation ?
