Fusion freaking out with lines in drawing
mainhannes
Message 1 of 8
mainhannes
Hello, does anyone know why Fusion is freaking out with the lines when i try to create a drawing from my model?
Missing lines and overall poor quality of the design represented in the drawing when zooming in and out.
https://a360.co/3HkBNQS
Replies (7)
Message 2 of 8
sutherland-
Hi @mainhannes
Does the issue persist when you export the PDF and open the PDF file? Or is it just within the software?
Try disabling this one in Preferences under Preview Features:
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 3 of 8
mainhannes
It is only in Fusion, not on the PDF.
No effect with highdpiscaling.
Message 4 of 8
sutherland-
Then I would say that you will have to live with it, since there are some known issues when it comes to visual representation within Fusion 360.
I have made a post long time ago regarding this, but no answer on why it is happening or when it will be fixed:
Zoomed out, inner part lines appearing
Zoomed In, no lines
Best regards,
Level  sutherland-
Member
Message 5 of 8
g-andresen
try  this
günther
Message 6 of 8
grishnakk
I have exactly the same problem.
It however persists when exporting in PDF.
Happens with all new drawings I am creating.
Message 7 of 8
TheCADWhisperer
@grishnakk
Can you File>Export your *.f3d or *.f3z file that exhibits this behavior to your local drive and then Attach it here to a Reply?
Message 8 of 8
grishnakk
Here's the file
