Fusion Crashes Upon Opening A Project - Related to doing a Manual NC Stop
tomGKJVK
Message 1 of 8
tomGKJVK
I was forced to update Fusion mid project because I had to reboot my computer.   Since updating, Fusion now crashes when trying to open a project I've been working on for 2 weeks.
I went back in the history and found a version that opened and then it crashed when I tried to move the M00 (manual nc stop) between setups.
I am using the Continuous Rest Machining beta flag - not sure if it's related to this at all, but I had no problems before the last update.
Replies (7)
Message 2 of 8
tomGKJVK
I can't touch this Manual NC Stop without it crashing.   Can't delete it, suppress it, or anything.
Message 3 of 8
paul.clauss
Hi @tomGKJVK
Does the problem occur if you turn off the continuous rest machining flag?
Are you being given the option to submit crash reports? If you are, please let me know which email address you are using to log into Fusion with (I didn't see any underneath the address on our existing email thread).
If you can share the file with me, I am happy to have a look!
Paul Clauss
Product Support Specialist
Message 4 of 8
tomGKJVK
Hi Paul,  Turning off the rest machining flag does fix it.   I’m kind of committed to using that at this point for this job, but I don’t need the Manual NC Stop.   I’ll add that myself after posting.
It does not prompt me to submit crash reports to Autodesk, only Apple.
I’m sorry, I cannot share this file.   I have worked around the problem and able to keep going.  I mainly wanted to bring this to someone’s attention so it can be fixed.
Message 5 of 8
paul.clauss
Hi @tomGKJVK
Thanks for posting. I'm glad to hear you've worked around and will try to reproduce the problem on my end. If you can share the file directly on our email thread, I am under the NDA described at this link. Sharing the file will help expedite a long term solution from dev.
I appreciate you making me aware of this behavior and will follow up here if I am able to repro.
Paul Clauss
Message 6 of 8
tomGKJVK
Hi Paul,
I’m sorry, I cannot share it.  I know it would be helpful.   Wish I could.
Some things that might be helpful – it’s 5 setups with Continuous Rest Machining running through all (except the first setup).  Lots of 3D adaptives.    The M00 was going into setup 3.
Message 7 of 8
pgYLCY4
I have a similar problem.  I can add a manual NC stop, but when I try to move it (change operation order), Fusion crashes.
Message 8 of 8
GalenYMW8K
I'm having same issue. Although mine is not when moving M00 into different setup, just moving different order in an operation. I also have to export this file and now can no longer open the recovery file, so I'm kinda.. screwed.
