Fusion becomes unresponsive after adding parameters
psych_uk
psych_uk
I've noticed that fusion stops responding if you add parameters.
At first I thought it was using the parameters that was causing the issue, however today I created a blank project and simply added a parameter (100mm), closed the parameter window and tried to create a sketch.
None of the buttons or menus work, although strangely I am still able to orient the workspace using the cube in the corner, and the close button still works and the application will close.
It's possible I may need to do a clean install so I would ask others to try to reproduce this behaviour so we may confirm or discard this as a bug.
Mike.
Please consider marking topics as solved after a solution has been established, this will prevent others from thinking the issue is still unresolved.
g-andresen
i have tested it several times in different new designs and could not observe the behavior.
Have you tried restarting?
Otherwise I would recommend the Service Utilities
günther
