Fusion 360 will not start, stuck on splash screen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone.
Fusion 360 will not start, stuck on splash screen, looks like all the program files start up, and if i do this workaround Fusion 360 start.
Walkaround i found after researching this issue for a bit is this:
If i go tho this location: C:\Users\xxxxx\AppData\Local\Autodesk\Web Services and delete Loginstate.xml, and restart my machine, i can start Fusion 360 again, just have to login and everything is fine.
I have read that updating the GFX driver can fix issues with Fusion 360, but i don't want to do that because of some other issues with the latest AMD drivers with my GFX card regarding gaming. And as Fusion 360 start after the workaround i found, i don't think this is related to my GFX driver actually. What i do not understand is how the program works after i delete Loginstate.xml, but will not work if i do not do the workaround.
Had this issue for awhile now, and it just starting to get old to have to do all this steps before i can start fusion all the time, so i want to get this fixed. The issue started a few weeks maybe a month ago, after a fusion update i think.
Anyone ells have this issue, and maybe know what the problem can be?
Including log and systemspecs below here.
Running latest Fusion 360 version (i think) had a update on it yesterday atleast.
Windows 10 Pro 64-bit (build:18363)(1909, codenamed "19H2")
AMD Ryzen 5 2600X
ASUS Strix RX580TOP 8GB
16GB Ram
NVMe SSD OS and programs installed
Please let me know if you need anything ells about my specs or anything ells.
