fusion 360 update
fusion 360 update
iuliancalin22
fusion 360 update
iuliancalin22
sometimes when i close fusion i'm getting that, "update later or update next session" message. is there no way to make it "update now or update later" ? or even a cancel button?
please 🙏
RajkumarIlanchelian
@iuliancalin22
when you launch Fusion, we check to see if there is an update available or not.
if there is an update available you will get a notification stating that there is an update available, gives you a choice to update or snooze. If you do not make a choice the notification goes away (but still available in the Notification Center).
Since you did not make a selection when you close it is presented with the option you see. Update later makes it snooze and update next session downloads the update the next time you start Fusion.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
iuliancalin22
but why not update now , that is my question
i don't always see the notification, and, even if i might forget about it, just let me update when i close it or make a cancel button 🙄
RajkumarIlanchelian
@iuliancalin22 I hear you on the "Why not update now". The current Fusion update is a two set process. The first is a download, then on the next restart it will switch to the new update. All these notifications and options give the go ahead to download. On the next start of Fusion they will be updated. The update next session you see is in a sort the update now.
We are talking about a preference for the updates where it would make it a lot more easier than trying to select these choices.
Autodesk Fusion
Join Fusion Insider
