thank you for the reply.
- in fusion, when i go to help, support and diagnostics, i don't see a "clear cache" only "diagnostic log files" and "graphic diagnostics". See can't do that. any help ?
- the second suggestion: I changed the names of the 2 files, it helped the first time I opened fusion 360.
so I closed fusion again (to be sure) and reopend it. The problem popped up again: no internet connection (I DO have connection) and 1 new .xml files with the name you mentioned also reappeared...(NNglobaloptions.xml).
And after the second opening of fusion I did see also the "clear cache data" at help menu..
So I cleared the cache, deleted the file, reopened fusion and.. no internet connection ...
Third try, I also cleared browser cache (again), then cleared cache data, then closed fusion, then removed the always reappearing file NNglobaloptions.xml (the other file didn't reappear again) then started fusion again ...
no internet connection....
So what now ?
Never never had that kind of problem with the older version of fusion..sorry but frustrated; why do they make such an update...
thanks for some more suggestions.
