Fusion 360 Toolbar Icons Disappeared After April 2021 Update
dan62Q5E
Message 1 of 171
dan62Q5E
Good afternoon. Since the update, I cannot see the icons in the Application Bar, Tool Bar, or the Timeline. The bars themselves are visible as grey strips and the functions are *there* and can be clicked even though they are not visible. I'm using a PC with Windows 10 Pro, 32GB RAM, and a GeForce 1660 6GB graphics card.
It just so happened that my Hobbyist/Personal licence expired today. I renewed it and the licence shows it is now valid until 2022. I don't *think* it's the cause but I thought I'd mention it in case I'm wrong about that.
So far I've tried a number of things to correct the problem but have met with no success. Things I've tried:
1. Restart Fusion 360.
2. Restart my PC.
3. Log out of Fusion 360 then Log back in. This caused the program to get stuck at the launch screen but I was able to correct that by logging into the Autodesk Desktop App and then launching Fusion 360.
4. Uninstall/reinstall Fusion 360.
5. Update my Nvidia GeForce driver to the latest version.
6. In Fusion 360, changed my video driver from DirectX 11 to DirectX 9 and even tried the OpenGL driver.
7. Uninstall/reinstall Fusion 360 using Fusion 360 Cleaner uninstall tool.
I've attached a Screencast capture of my dilemma to illustrate the problem. I'm not sure what else to try and would be grateful for suggestions.
Dan
Replies (170)
Message 101 of 171
wtf man. I got school stuff to do. plz fix
Message 102 of 171
wtf man. i got some schuul stuff to do. come on now
Message 103 of 171
nikitanugent
I just paid for my first year of a commercial subscription, and then immediately started getting this error. I suppose it updated after I got the subscription? I had installed the trial version on April 20th, after this seems to have already been an issue, but it only started giving me this error after I actually paid for a license.
The work-around works, sort of. After I tried deleting the variable it stopped working again, and re-entering the variable gets me the same problem as FowrassEngineering, sometimes:
Other times the menus are just missing completely, not even black. If I open and close the data panel, the section over the menu remains. But then alt-tabbing a bunch makes the menus show up, eventually. Here I am hovering over the invisible fillet button:
It seems random as to whether or not it starts correctly or displays that error. Right now things are functioning correctly again. It really is ridiculous that this version is still being distributed, given the wide array of systems affected.
How will we know when a fix is available so that we can delete this system variable?
Here are my specs, in case that helps:
Fusion 360:
2.0.10143
Active Plan: Fusion 360, Subscription
Windows 10 (19042)
Graphics:
Intel® UHD Graphics 620
Adapter RAM: 1.00 GB
DirectX Version: DirectX 12
Driver:
Provider: Intel Corporation
Version: 23.20.16.4973
Date: 2/28/2018
Operating System:
Edition: Windows 10 Home
Version: 20H2
Installed on: ‎2021-‎04-‎27
OS build: 19042.928
Nikita
Message 104 of 171
daniMendler
Observer
Observer
Adding this environment variable:
QT_OPENGL = software
it has worked for me.
Message 105 of 171
jculleton3
I had to "run as Administrator" fusion after I did the work arounds.
Otherwise I still get the black bars.
I am glad the work around kinda works since it is time to submit my BattleBots application...
Message 106 of 171
Same problem occurred even after trying the solution described.
Message 107 of 171
hijazh
Thanks Lance. The fix you highlighted in message 29 resolved my black bars also. Any update on when the software patch with a more permanent solution will be ready?
Message 108 of 171
visserCGWTG
This has become a problem for me since the update today (28th april 2021) which. The problem therefore seems to have worsened since last time instead of improved.
Message 109 of 171
This worked!! Thanks a lot for this workaround.
Message 110 of 171
cristian_berti
Community Visitor
Community Visitor
Same problem , solved by following the instructions . Thanks.
Message 111 of 171
cklfp
Hi.
I confirm the language change, the icons do apear, but the tool library, is still black.
Message 112 of 171
qztk
Community Visitor
Community Visitor
Same thing happened to me (the April Windows 10 update)
I did everything the OP said before finding this forum and nothing worked.
lance.carocci 's solution worked well. Thanks!
Message 113 of 171
it worked
Message 114 of 171
subteblu
Hi, this worked for me.
With the "software" variable activated. Open Fusion, although the top menu is black, with the mouse you can go to the right corner and enter user preferences. Choose DirectX 9 as the video driver.
After restarting Fusion it looks fine.
Message 115 of 171
I have tried everything above.  Set System Variable QT_OPENGL = software      -   did not work
it changed the Black bar at top and bottom to a white bar.   Tried running as Admin  no change.  Went to Preferences and changed to DirectX 9 for the graphics Driver.  That didn't fix it either.  So last ditch I tried changing the graphics driver to OpenGL Core Profile.  That is now working.
Message 116 of 171
Capture.PNGMeshmixer opens up after adding the QT_OPENGL variable but with a black screen just like the black tool bar.
The toolbars appeared back in the fusion360 though. .
Message 117 of 171
sstephe1622
Fusion360 seems sluggish after the update.  I've had problems getting into the tool library.  The posted fix seems hit or miss depending.  I open Fusion to have no ribbon bar to close and reopen the program to have the ribbon bar back.
Also noticed that the comments is gone.
Message 118 of 171
6stringsplus2WSJR
Switching User Language to German fixed the black bar issue for me.
Message 119 of 171
jonasV8EPL
Observer
Observer
I have the same issue. The Toolbar is blacked out.
So I logged out and log back in, but now the log in screen is blank.
I need Fusion ASAP!!!!! I have people waiting on projects.
Message 120 of 171
This fix worked for me, the toolbar was black after the latest software update.
I'm running on an old Lenovo T430 laptop with Intel core i5 processor. No dedicated graphics card.
Thanks for the Fix bro.
