Slice inside sketch remains after closing the sketch (video)
betztechnik
betztechnik
You can see the video but if I slice a sketch and close the sketch, the model continues to be sliced.
Peter Betz
Betz Technik Industries Ltd.
jeff_strater
OK, I'll log that bug.  Thanks for reporting it
[edit] created bug FUS-80941 for this issue.
Jeff Strater
Engineering Director
jhackney1972
Have your created a simple new model and tried the same process on it to see if you can duplicate the issue?  I know it is not a normal process but what happens if you select Compute All, located in the Design Environment under Utilities?
John Hackney, Retired
betztechnik
@jeff_strater  just to add to this, it appears to only happen when the component that the sketch belongs to is NOT activated.
@jhackney1972  I tried update and compute all and I thought that fixed it until I notices what actually triggers it (component not active).
Peter.
