Fusion 360 Personal stuck in trial mode
djflow195
Message 1 of 16
djflow195
My personal license ran out so Fusion 360 started in trial mode.
I renewed the license at https://www.autodesk.com/products/fusion-360/personal and was successful in downloading the Fusion 360 Client Downloader.  When I logged out and back in Fusion 360 still shows trial mode.  I tried again a few days later with the same result.  I tried to uninstall and reinstall, same result.
Any ideas?
Replies (15)
Message 2 of 16
Somnambulist1
Did you ever figure this one out? Currently having the same problem...
Message 3 of 16
jhackney1972
It seems you are all set with your renewed license. Autodesk recently changed the renewal of a Personal license to begin with a full subscription trial. When this trail ends you will be switched to your Personal license. They are hoping you will like the full subscription version enough to purchase it and not continue using a personal license.
John Hackney, Retired
Message 4 of 16
jhackney1972
I meant to respond to you, as you are the most recent poster.  Please refer to the Original Poster question and answer.
Message 5 of 16
ncglad
Is this what's happening to me? Do I need to let my current subscription expire, then install the trial in order to renew my personal use license?
My personal use license expires in 6 days, but I've been unable to renew using the process I've used before: (log out of Fusion, log in to my Autodesk account on the web and renew, download the installer, wait 30 minutes, then log back into Fusion)
So far, following the process above has been unsuccessful, it continues to say "expiring in 6 days", regardless of what I do.
Message 6 of 16
jhackney1972
The process used to be:
  • Wait until the Personal License expired completely
  • Go to the Person License renew webpage, selecting the proper license to renew
  • After the renewal form is filled out, you were taken to the Download page
  • Download and install regardless if it is already installed or not.  Uninstalling existing application was not necessary
  • One year renewal Personal License started immediately
The process as I understand it to be now:
  • You will not get a 30 day trial of the full Subscription License to try.  This is Autodesk method of advertising hoping you will want to sign up for the full subscription license.
  • (This is the part I cannot verify right now) After the 30 trial ends, you will be switched to your new Personal license, either automatically or using some other method.
I use a Personal license, to help me work with questions involving this type of license, which comes up for renewal in 5 days.  I will be documenting the process I use to renew and develop a process for others during my renewal process.
I can say for sure, you DO NOT go out and sign up for a 30 day trial on your own.  You also should wait until your current personal license runs out.
Message 7 of 16
ncglad
Thank you. Your personal expires one day before mine does. I'll check back in 5 days.
Message 8 of 16
djflow195
I resolved my issue.
Turns out the form at https://www.autodesk.com/products/fusion-360/personal-form was broken and not showing me all the required fields.  I would submit the form as was presented and could not continue to the download page.  Eventually the trial expired and I was stuck with no license.
I am not sure what I ended up doing but I eventually got the form with all the required fields shown.  Filling out and submitting this iteration worked.  I now have the personal license.
Message 9 of 16
ThomasF7WDB
Does Autodesk really think that constantly making life miserable for hobby users will encourage them to pay for Fusion? Wasted another hour this morning trying to solve the Trial subscription issue because I hoped it would resolve my "Can't create new project" issue - but that appears to be a different bug.
Message 10 of 16
kirelam
Community Visitor
Community Visitor
Dear Autodesk,
Unfortunately my Fusion360 also keeps saying, that I have a Trial version. This is not the program itself, due to it online also saying that it is a trial.
If this is an error, could you advice me, or correct it?
Kind regards,
Eric W
Message 11 of 16
g-andresen
Keep your feet still until you get the "Expired  Subscription -Read Only" notice.
Then follow the series of images.
günther
Message 12 of 16
kirelam
Community Visitor
Community Visitor
Dear guenther.andresen,
Thank you for the help.
Will wait my 30 days of trial, and then try your solution!
Kind regards,
Eric W
Message 13 of 16
Somnambulist1
Updating this because it turns out the responses are wrong - at the end of the trial period my copy of Fusion360 just died, now I can't figure out how to reactivate it without paying for one of the exorbitantly expensive commercial plans.
Message 14 of 16
pancakeparty
Community Visitor
Community Visitor
holy you are the best
Message 15 of 16
musmiris69
Hello all,
Did someone find a solution for this Personal/Trial license thing? Today I renewed my "personal license" and downloaded installer 2 or 3 times. Uninstalled, reinstalled software. Still "Trial ends today".  Inside plans/pricing - trial has ended. And there is no possibility to select "personal license"
None of preciously mentioned solution work for me.
Message 16 of 16
musmiris69
Newer mind. It look like somehow I started trial without noticing it. On the trial period system does not show you have a working personal license. Just trial without any other license. And this is confusing. After end of this trial there started normal personal license
BTW in autodesk account or setting there is no any information I have some personal fusion license. I can see it in the fusion software only
