Fusion 360 hangs on launch / unresponsive
disbeleiver
Message 1 of 10
disbeleiver
Community Visitor
Community Visitor
Trying to use Fusion for the first time. Installed it 30 mins ago, I assume this means it's latest version. On first launch I clicked through team setup and then application launches, I see interface, grid and then tutorial explaining free version limitations pops up. I click "OK", button hover animation is drawn, but popup does not close. I may still hover the button, but no help. Window decorations are unresponsive too, I can't minimize window for example (likely because of popup). Killing process and relaunching does not help. It does not eat CPU, RAM, or network.
Windows 10 x64 Version 10.0.19041 Build 19041,
Dual E5 Xeon, 16C/32T, 128 GB RAM, 1080 GTX, 157 GB free on system drive.
Internets are 200+ mbps to major IX points, I'm in Central Russia.
Replies (9)
Message 2 of 10
RajkumarIlanchelian
@disbeleiver Thank you for providing all the right details here. This could be a graphics problem. Can you please check to make sure that here are no pending driver updates?
 When you mentioned that you tried to kill the process, did not have any luck, did you keep seeing the pop ups that are unresponsive?
Can you shut down Fusion 360. Disconnect Internet, launch Fusion and see if the experience is any better and if it is in that state connect back to the internet. What happens?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 10
Phil.E
Hi, do you use more than one monitor?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 4 of 10
leandrotoledodesouza
I'm not the OP but I'm having the same problems. Similar setup as well. I have two monitors.
Message 5 of 10
RajkumarIlanchelian
@leandrotoledodesouza Can you check out the solution in this article to see if it helps?
Autodesk Fusion
Join Fusion Insider
Message 6 of 10
No luck, unfortunately. All my drivers are updated with a clean Windows
install running the latest updates.
Message 7 of 10
Regarding the video card, I have a RTX 3070 running the NVidia Drive version 461.72 released on 2/25/2021 (latest).
Not sure if this helps with anything, but here's the latest AppLogFile:
20210303T214808 I Version : 2.0.9849
20210303T214808 I UTC offset : -5
20210303T214808 I Loading configuration from:C:/Users/leand/AppData/Local/Autodesk/webdeploy/production/d61caf495bff6c1f315f777537e978cd28259ee4/Fusion 360.server.config
20210303T214808 I SLM: device id = 08d5d0c6-34f6-2f26-2ac5-df06c65dfdd0
20210303T214808 I SLM: Initialized
20210303T214808 I WorkflowTrackManager Initialized with:0 items
20210303T214808 I Disk capacity: 399,383MB Disk free: 328,207MB Percentage free: 82 UIThread: no Time: 0.00015s
20210303T214808 I AnalyticItemCounts Initialized with:0 items
20210303T214808 I 	searchAndLoad exec path: C:/Users/leand/AppData/Local/Autodesk/webdeploy/production/d61caf495bff6c1f315f777537e978cd28259ee4/Fusion360.exe
20210303T214808 I PROXY: WindowsProxyOptionId set to Automatic		ThreadID: 7552, Function: `anonymous-namespace'::logProxyOpIfChanged, Line: 920
20210303T214808 W PROXY: failed to query IE proxy configuration - The Proxy Auto-configuration URL was not found.
20210303T214808 I PROXY: proxy server set to DIRECT		ThreadID: 7552, Function: `anonymous-namespace'::logProxyUsedIfChanged, Line: 947
20210303T214808 I SYNHUB: Loading config files in directory C:/Users/leand/AppData/Roaming/Autodesk/Synergy
20210303T214808 I SYNHUB: Loading config file C:/Users/leand/AppData/Roaming/Autodesk/Synergy/NLauncher.syncfg
20210303T214808 I Request(https://ui-dls360.autodesk.com/fusion/version.txt) - workflow: attempt:0 status:200 requestId:
20210303T214808 I Request(https://a360-statusdashboard.s3.amazonaws.com/autodesk_maintenance.json) - workflow:HTTPClient attempt:0 status:200 requestId:f360_HTTPClient__1-60404a68-28a2e06aaf4949d48138fc84
20210303T214809 I Request(https://ui-dls360.autodesk.com/fusion/maintenace_services.txt) - workflow:HTTPClient attempt:0 status:200 requestId:f360_HTTPClient__1-60404a68-7e94c5f87b99422abdf302c6
20210303T214809 I LaunchDarkly client initialization process is finished successfully!		ThreadID: 3960, Function: Ns::LDCSDKWrapper::initLDCallback, Line: 341
20210303T214809 I LD CSDK for type Global was initialized with a total time of 0.000002 seconds		ThreadID: 4720, Function: Ns::CSDKLDFeatureFlagsManager::getFlagValue, Line: 141
20210303T214809 I Load Feature Toggle Xml:C:/Users/leand/AppData/Local/Autodesk/webdeploy/production/d61caf495bff6c1f315f777537e978cd28259ee4/Fusion/Server/Fusion/Resources/FeatureToggle/FeatureToggle.xml
20210303T215115 W ServicesHealthStatus: Health Status response is not json
I tried to open the URLs mentioned here on my browser just to rule out DNS / Connectivity issues and I got proper responses:
ZipFilename:fusionsrcv1102.zip
BuildVersion:v1102
BuildDate:02/20/2018
Service:FusionJS
	"language": "enu",
	"timestamp": "2014-01-17 06:03:10 AM",
	"messages": {
		"dealsMessage": {
			"default": "en-US",
			"en-US": "New year, new tools - %6%. Offer ends Jan. 31.",
			"de-DE": "Neues Jahr, neue Werkzeuge - %6%. Das Angebot endet am 31. Januar.",
			"ja-JP": "新しい年、新しいツール。%6%。オファーは1月31日に終了します。",
			"zh-CN": "新的一年,新的工具。%6%。优惠截止至1月31日。"
		"bannerUrlText": {
			"default": "en-US",
			"en-US" : "get ahead of the curve with our best deals ever",
			"de-DE" : "Gehen Sie mit unseren besten Angeboten immer einen Schritt voraus",
			"ja-JP" : "これまでで最高の取引をしてください",
			"zh-CN" : "获得我们最好的交易"
	"product_list": {
		"A360PRO": {
			"product_code": "A360PRO",
			"maintenance_details": [
					"start_time": "12:00",
					"end_time": "12:00",
					"reason": "Banner",
					"severity" : "Informational",
					"delay" : "0",
					"key" : "JAN_DEAL04",
					"start_date": "24/01/2020",
					"end_date": "31/01/2020",
					"banner_message":"dealsMessage",
					"banner_url_text" : "bannerUrlText",
					"banner_url": "http://autode.sk/jan2020offer",
					"offline" : false
    "services_maintenance_period": 168,
    "services_code": [
        "Oxygen",
        "Hydrogen",
        "Translation",
        "PLM360",
        "A360PRO",
        "ExchangeServices",
        "Neutron",
        "Nitrogen"
    "Fusion360" : "",
    "Simulation" : ""
Message 8 of 10
RajkumarIlanchelian
@leandrotoledodesouza Thanks for the extra logs. I take it that you tried the solution for multi monitors from the article that I posted and it did not work. Have you tried using a single monitor and starting Fusion? Will take a look at the new logs posted.
Autodesk Fusion
Join Fusion Insider
Message 9 of 10
Hi Rajkumar, thank you. Correct. I tried the article, I unplugged my second monitor and I had no luck.
I opened Fusion and left it running over night to see how the logs would unfold, and I was surprised to see it was working in the morning.
It took around 10 minutes, I see lots of "W ServicesHealthStatus: Health Status response is not json" in the log file before it prompted the Login screen; suggesting failed attempts to parse the webservice response (even though I could see it via browser).
Maybe it was just an unavailability on Autodesk Services? I can confirm Fusion is working normally for me now.
Thank you for your support.
Message 10 of 10
RajkumarIlanchelian
@leandrotoledodesouza Glad to know that you are back with Fusion. In the past we have also found reseting your router takes care of the issues. A change to the DNS may sometimes cause retires to connect with services.
Autodesk Fusion
Join Fusion Insider
