Fusion 360 won't update
cowellscustoms
cowellscustoms
i have tried updating fusion 360, and unfortunately it always has an error. it has stated to look at the logs and i have found 3 logs but can't tell from them what is wrong.
i can post the log here but I'm not sure which one is needed. The three i can find are:
Autodesk Fusion 360_2021-03-01-134706_Marshalls-MacBook-Pro.wakeups_resource
Autodesk Fusion 360_2021-03-03-141436_Marshalls-MacBook-Pro.cpu_resource
Autodesk Fusion 360_2021-03-03-173954_Marshalls-MacBook-Pro.cpu_resource
jhackney1972
One of the main logs to post is the autodesk.webdeploy.streamer.log.  If you cannot find it, use this article to locate the log files.
John Hackney, Retired
cowellscustoms
Please let me know if you are seeing my post with the log info. I have posted it now twice and don't see it as a reply to you.
RajkumarIlanchelian
@cowellscustoms Unfortunately I don’t see any attachments. While you try to attach it again , one way to get moving forward is to re-install the product which always gives you the latest version. This is not the recommended way but until we can figure out what is happening reinstall could be a way to move forward.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
