Fusion 360 doesn't start on my MacBook Pro version 10.13.6
gelmir99
gelmir99
Hi All.
Starting F360 i receive this message (till yesterday all was fine):
Impossibile aprire Autodesk Fusion 360 a causa di un problema.
Consulta lo sviluppatore per assicurarti che Autodesk Fusion 360 funzioni con questa versione di macOS. Potresti dover reinstallare l'applicazione. Assicurati di installare tutti gli aggiornamenti disponibili per l'applicazione e per macOS.
Process: Autodesk Fusion 360 [13254]
Path: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Identifier: com.autodesk.fusion360
Version: 2.0.6263 (2.0.6263)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Autodesk Fusion 360 [13254]
User ID: 501
Date/Time: 2019-09-29 20:27:07.664 +0200
OS Version: Mac OS X 10.13.6 (17G8037)
Report Version: 12
Anonymous UUID: B81070AE-7299-C197-1344-EA250D570227
Sleep/Wake UUID: 698F2B04-0D92-4F43-BECA-2F371AE6B2E1
Time Awake Since Boot: 66000 seconds
Time Since Wake: 10000 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/Qt/QtCore.framework/Versions/5/QtCore
Referenced from: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Reason: image not found
Binary Images:
0x10fe24000 - 0x10fe42fff +com.autodesk.fusion360 (2.0.6263 - 2.0.6263) <F5B9EEDD-2670-37C0-B62E-99C2FF5512F2> /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
0x11c0a8000 - 0x11c0f2acf dyld (551.5) <30B355CB-35BA-3112-AA76-4E46CD45F699> /usr/lib/dyld
Model: MacBookPro6,1, BootROM 99.0.0.0.0, 2 processors, Intel Core i7, 2,66 GHz, 8 GB, SMC 1.57f18
Graphics: Intel HD Graphics, Intel HD Graphics, Built-In
Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334348302D4346382020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334348302D4346382020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.102.30)
Bluetooth: Version 6.0.7f15, 3 services, 27 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Network Service: Parallels Shared Networking Adapter #0, Ethernet, vnic0
Serial ATA Device: Crucial_CT1050MX300SSD1, 1,05 TB
Serial ATA Device: HL-DT-ST DVDRW GS23N
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Hub
USB Device: Hub
USB Device: AS2115
USB Device: USB Receiver
USB Device: IR Receiver
USB Device: Built-in iSight
Thunderbolt Bus:
Please help me to have F360 up and running again
Thanks in advance
Regards
Mirco
James.Youmatz
Autodesk Support
Autodesk Support
Hi @gelmir99 ,
Can you try the instructions in this forum post here?
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
gelmir99
Hi All.
In the meantime i found the forum support suggestion and it worked for me.
Now my F360 is up and running perfectly.... WOW ...now i can breathe again !!!
Thanks thanks thanks thanks a lot for your help and effort
Regards
Mirco
