Fusion 360 after upgrade, mac problems, unable to 3d print, and very slow
Message 1 of 26
This was working, but now it is not after the latest upgrade.  I used to be able to send files to be 3d printed, to my simplify3d application, using a mac.  Now, I cannot do this.  It says, "
Fusion 360 does not have sufficient privileges to launch the Print Utility. The Print Utility must be manually launched once in order allow Fusion 360 to launch it. Please launch Print Utility from the Applications menu."
But I can't find any print utility or applications menu.  I've restarted both apps and rebooted and the problem still exists.
Also,  Fusion 360 is hanging all the time, with the beachball.  It is extremely slow now.
Please advise.  Thanks!
Wendy
Replies (25)
Message 21 of 26
Yes, i did and won't work. Also, none of the file types available for export from fusion can be imported or opened by meshmixer
Message 22 of 26
Phil.E
@Anonymous
I'm going to ask Support to contact you regarding the failure to connect to meshmixer within Fusion.
Regarding the file types opened by Meshmixer, try using Import.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 23 of 26
I tried to open and import. No file works…
Parenthetically, all other printing softwares (Print studio and PreForm) open by Fusion without an issue…
E
Message 24 of 26
Phil.E
This is starting to sound like a Meshmixer problem. Do you have the latest version?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 25 of 26
Yes, Version 3.2.37
Message 26 of 26
I just fixed the problem.
Uninstalled Fusion with its subfolders (I used AppCleaner) and re-installed Fusion…
