Fusion 360 install issues
I'm Michael from Spring TX, and began using ACAD V 2.5 in 1986 and using the different versions through now. I am an enthusiast creating parts mechanical, electromechanical and electronic.
Recently I was shown Fusion 360 and am interested in trying it out, so I downloaded it onto a Sony Vaio laptop from 2010 that has the OS Windows 7 with SP1.
I've run into the problem where Fusion 360 tries to start up after the install and reports the following failure message:
"Failed to execute "<my installation directorypathname for> Fusion360.exe"
"Returned error: 0x000000c1" Please uninstall Fusion360 and reinstall; if this does not correct the problem please contact Autodesk for technical assistance."      I tried clicking your Chat button but the webpage showed a message line that said Chat was not in service on December 26, so I looked online for blogs about this error and several folks had posted they had the problem but I didn't see other actions that solved it.
I did uninstall, and reinstall Fusion360, but the same failure to startup Fusion360 occurs. So I installed a fresh copy of Windows 7 with SP1, however the very same problem still is occuring. I met a Microsoft technical expert yesterday at the Microsoft store and he said that I had taken his advised step installing the fresh copy of Windows 7 with SP1 and all the Windows updates.
Can you advise me what to do to eliminate the "Failed to execute "<my installation directorypathname for> Fusion360.exe"
"Returned error: 0x000000c1"    ?   I look forward to having it startup and trying it out Fusion360.
Thanks for any help you can give,
Michael
 Edited by
Discussion_Admin
Oceanconcepts
Hi Michael,
I won’t be much (any) help with Windows install issues, but there are suggestions for finding log files in this thread.
http://forums.autodesk.com/t5/design-validate-document/fusion-360-install-problems/m-p/5436774/highl...
The forum is very active, but giving your post a descriptive title like “Windows 7 install problem” will probably generate a quicker response from those who can help.  Graphics cards are a common source of issues, so specifying what you have installed and the drivers may be helpful.
Welcome! Hope you get going soon.
- Ron
Mostly Mac- currently M1 MacBook Pro
innovatenate
Autodesk Support
Autodesk Support
Thanks for posting and sorry to hear about the troubles. I've seen a similar error message reported before, but it appears to be different then this issue.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
If you've installed a fresh copy of Windows 7, I think we can safely assume that there are no lingering start-up icons from an old version around. 🙂
I do have a couple of suggestions that may help:
  • Try right clicking on the start-up icon and selecting the Run As Administrator option
  • Try browsing to the isntallation location %LOCALAPPDATA%\Autodesk\webdeply\production\ and searching for Fusion360.exe. Are you able to launch the application by executable directly?
  • Do you have any anti-virus software that could be interferring with the launch of the application? Try temporarily disabling it.
  • You could test temporarily lowering the User Account Control Settings to the Never Notify level to see if that has any impact.
I hope these suggestions help. Please keep us updated on your progress or if you have any questions!
Nathan Chandler
Principal Specialist
hello ,this is slinna from China
