FIXED: Error: Unresolved Components in Assembly after March Update
James.Youmatz
Autodesk Support Autodesk Support
Message 1 of 21
James.Youmatz
Autodesk Support
Autodesk Support
Hi all,
We have recently become aware of an issue when opening an assembly with linked (XREF'd) parts, that it may throw an error saying "Error: This Document may contain Unresolved Components" and the assembly links and components are broken.
In this event DO NOT SAVE THE DESIGN and DO NOT PROMOTE PREVIOUS VERSIONS OF THE DESIGN. In doing so, the links may be broken, and as a result, a previous version will have to be promoted after the fix is deployed to restore the links.
We are working very diligently to solve this issue and post a fix within 24 hours. As soon as it is released I will update this post.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Replies (20)
Message 2 of 21
works_camera
Thanks for letting us know. This is a serious issue for me, as it has ground the design process to a halt.
Message 3 of 21
j.hancock01
Hi James,
Thank you for your post and the great work you and the team are doing. I've also seen the "unresolved component" error message. I think this error could also be the root-cause of the odd appearance of a linked subassembly that I posted about yesterday. I was in the process of trying to re-build a model as I'd got the unresoved component error when the error in the link below occurred:
https://forums.autodesk.com/t5/fusion-360-support/imported-component-different-from-original-compone...
Good luck with your work fixing the issue. I'm sure we're all looking forward to hear about the fix.
Many thanks
Jon
Message 4 of 21
michael55SE4
Thanks for letting us know you're working on it.  Bugs happen in software, and when they do I appreciate that you guys acknowledged the problem and are working to fix it.
Unfortunately I've been unable to work on my project yesterday, and presumably all day today, so I hope you find a solution soon!
Message 5 of 21
michael55SE4
I was hoping to work on different projects today, but apparently every single model in my repository is giving this error 😞     No idea what's causing it, but my models all use a variety of parts that are referenced.
Guess I'll read a book?
Message 6 of 21
Im also having this issue since I updated to the latest version this morning. A quick fix would be greatly appreciated!
Message 7 of 21
Thank you for your attention in fixing this major bug. Do you have any updates on the status of a new release? Many of us are not able to work on our projects because of this bug.
Message 8 of 21
rcsun
Yeah this is a major bug that needs to be fixed immediately. I cant believe its been almost 24 hours and nothing yet. I've been at a complete standstill, not about to go rebuild an assembly that has over 150 parts.
Message 9 of 21
jeff_strater
We are planning to release an update with a fix to this today.  This is our highest priority, and we will get it out as soon as we can.  We apologize that it has taken so long to get the fix released.
Jeff Strater
Engineering Director
Message 10 of 21
jeff_strater
just got word - the fix is out.  If you exit and re-start Fusion you will get the update.  We apologize for the disruption.
Jeff Strater
Message 11 of 21
rcsun
Great! That was a painful 24 hours. To prevent these kind of things in the future, is there any way to optionally roll back the software update until the fix is implemented?
Message 12 of 21
kamolc_hg
After March 13 update, the problem still occur to my work.
Message 13 of 21
m_maursundFZNS2
I still have the issue.
Update:
Looks like the issue is solved now.
Martin
Message 14 of 21
maximilian.lacher
Have not seen the issue in the past, but after the latest update we now receive the same issue
Update:
Martin
Message 15 of 21
stiller.design
the issue is still not solved, is it?
Message 16 of 21
James.Youmatz
Autodesk Support
Autodesk Support
Hi @stiller.design,
It should be fully resolved after the hot fix we deployed last week. Can you confirm you are on version 2.0.5511? To confirm, click the Help menu of Fusion in the top-right corner and select About.
James Youmatz
Message 17 of 21
j.hancock01
I found I needed to "refresh" the models I was working with in order to completely get rid of the problem. This is described in step 2 of the solution to another related problem I was having:
Message 18 of 21
mjoconr
I'm dealing with issues where models which where not save are now damaged, so I think there is still some sort of issue but what is up for investigation.
I have a model which is being looked at by people at Autodesk.
Message 19 of 21
stiller.design
Hi James, thanks for your reply, Yes I on the latest version, the same you mentioned.
I also get lots of error messages opening a drawing. For 1 drawing I open I get error messages
shall I open a new thread for that?
Message 20 of 21
James.Youmatz
Autodesk Support
Autodesk Support
Hi @stiller.design ,
I would. This seems different and I'd like to make sure we capture that correctly.
James Youmatz
