Fix constraint missing
Ex_Machina_Engineering
Hello guys,
I'm using the new UI (which I really like) and in the sketch environment, the constraints buttons are all moved to the ribbon. So no menu on the right side as before. But I cannot find the "fix" constraint. Is it just me being blind or is this a real issue?
+1,000,000 on this!
This is a real problem that needs to get fixed ASAP! (Or sooner 😉
JWhitten
Phil.E
Thanks for reporting this. We're taking care of it. Sorry for any inconvenience.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
TheCADWhisperer
@Phil.E
Can you post screenshot of "New Interface"?
I reset every Default I can find in Toolbars, Panels and Preferences - restarted Fusion and all looks the same to me?
OK, I found it - in Preferences>Preview Functionality.
Thanks!
BTW, I found out that the 'Fixed' constraint is still available in the right-click pop-up menu.
John
HughesTooling
Don't know if anyone is looking at the preview forum but I reported this and the curvature constraint is missing too.
Mark
Mark Hughes
Owner, Hughes Tooling
Also, another thing I noticed was that when you isolate a part in an assembly you don't get the Unisolate command anymore. So you have to go to the assembly parent and hit unisolate all.
BTW, right-click menu workaround was cool. Thanks
