Fillet trouble
Fillet trouble
PetePayne
Fillet trouble
PetePayne
Good Morning!
I am having trouble applying a fillet to the area against the falt in the srea highlighted in the red circle.
What is my best plan of attack?
Also the file save option isnt working ?
If I could save it I would upload the actual file.
Thanks for the help!
James.Youmatz
Autodesk Support
Autodesk Support
Hi @PetePayne,
Not sure why you do not see the Save option to be honest. Are you in the Model workspace or a different workspace? Are you able to go to the File menu and select Share-Share Public Link and send me the link to download the file. I can then look deeper into your model to see why the fillet might be failing.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
PetePayne
Well the save and save as buttons were gray'd out and I could not click them.
I am going to clost Fusion360 and reboot my computer . It has bee a long time since I closed fusion.
I will report back.
HughesTooling
Did you try Export and save as an f3d file you could uploads here?
Mark Hughes
Owner, Hughes Tooling
PetePayne
That also would not work. It looks like the reboot of the computer has helped . I was able to save the file . I am going to try and upload it now.
HughesTooling
You've ended up with 3 bodies, you can't fillet between different bodies. In the screencast below I rebuild the part with the extrude features set to join. You could edit what you have but you where using far more extrudes than you really need. The file's attached, import with New Design From File on the file menu.
Mark
Mark Hughes
PetePayne
Wow, that looks so much easier the way you did it.
You can tell I struggle.
Thanks for the help and clarifying the way to do this.
I will import the file and keep practicing.
Thanks so much!
