@TheWebExpert
On the web, can you check your trash? Go to the project it should be in, then open the trash at the top. I see a 'delete' action occurring in the logs at 4:45pm on 10-24 of the file RTG. If you didn't initiate that, that is concerning. I'm investigating some other data loss issues as well.
20221024T164524 I 2332 Workflow start: delete 1-6356f963-39f40f9e569943b89a772c24
20221024T164530 E 4300 Network failed request - response NOT OK:
URI:https://developer.api.autodesk.com/wipdata-serv/storage/v3/lineages/urn:adsk.wipprod:dm.lineage:kYhgE1YoTEaBZiwMztsZZg
...X-Request-ID: ContentBrowser_c462a7c4-143d-49c7-aa69-08b31f7cd3f9__fileRefresh_urn.adsk.wipprod.dm.lineage.kYhgE1YoTEaBZiwMztsZZg
...response: HTTP/1.1 404 Not Found
Connection: keep-alive
Content-Encoding: gzip
Content-Length: 84
Content-Type: application/json
Date: Mon, 24 Oct 2022 20:45:29 GMT
Strict-Transport-Security: max-age=31536000; includeSubDomains
Transfer-Encoding: chunked
Vary: Accept-Encoding
X-Content-Type-Options: nosniff
X-Frame-Options: DENY
X-XSS-Protection: 1; mode=block
{"errorCode":"LIN_NOT_FOUND","errorClass":"ApiError","message":"Lineage not found."} ThreadID: 4300, Function: Ns::Network::ReqUtils::logRequestError, Line: 322
20221024T164530 D 2856 ActiveDocumentCache: uploader thread started
20221024T164530 I 2856 [OS3] START uploadFile file:login__ActiveDocuments urn:adsk.objects:os.object:fusion.prefs.login/5YJQQXGWQVP5__ActiveDocuments
20221024T164530 I 22984 PushNotification broadcasting 0007 a360prod%3Agroup%3A19395472 groupSubscription
{"message":[{"message":{"wipVersionUrn":"urn:adsk.wipprod:fs.file:vf.kYhgE1YoTEaBZiwMztsZZg","state":"CONTENT_AVAILABLE","name":"RTG","parentFolderUrn":"urn:adsk.wipprod:fs.folder:co.Vrr6ZCdzTVqQAFuE7hkvig","lineageUrn":"urn:adsk.wipprod:dm.lineage:kYhgE1YoTEaBZiwMztsZZg","projectDmid":"a360prod:group:19395472","branch":"master","branchUrn":"urn:adsk.wipprod:dm.branch:BjAfJ-GMSxGlauIW2LASnQ","eventType":"WipFileDelete","eventId":"0bcfe3c3-7a62-405d-a99c-cdd80af3f27d","sourceServiceTrackingId":"ContentBrowser_68a72bc0-23c2-4b55-893c-d4b842051299__filesDelete_urn.adsk.wipprod.dm.lineage.kYhgE1YoTEaBZiwMztsZZg-Clone-0.WIP-bc5209e8-f29a-4303-8085-2abf78ea4cd4"}}],"channelStatus":["available"]}
20221024T164530 I 2856 [OS3] GET 200 /oss/v2/buckets/fusion.prefs.login/objects/5YJQQXGWQVP5__ActiveDocuments/signeds3upload file:login__ActiveDocuments requestId:f360_ActiveDocuments__1-6356f96a-acf546460244450299b0a957 dt=0.27 key=AQICAHif~ily6OqA= expires=2022-10-27T00:00:00Z ttl=184470 urls=1 (1)
Cheers,
Karina
