File is Corrupted
File is Corrupted
bkent.kenrett
File is Corrupted
bkent.kenrett
A component I used a few days ago is now corrupted and wont open, nor will any designs it is used in.
They do however open online.
I have tried a clean install of Fusion to no avail, file still won't open.
The error message is either:
"Could not open file Error opening file! The current operation will be aborted. File name: 70 v133"
Or:
"Corrupt File The file you are trying to open or operate is corrupt! The current operation will be aborted. File name: _70.a583c91b-1775-486d-9d8d-f5935097cef7.f3d"
Previous versions won't open either, at least as far back as is acceptable to redo the changes.
I am not permitted to share the design publicly
Please assist.
bkent.kenrett
3rd Clean uninstall and reinstall with no luck, another file found to be corrupted too and won't open.
Please advise Autodesk if this is just me or are there others. It is ever since the update!
daniel_lyall
Try going into the file system and see if the file is in there then if it is copy past the file onto your desktop and see if it will open in fusion https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
As you say it opens online so it might be there and not corrupted I had a file disappear and found it using what's in the link above.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
mohammed.aliTDPXK
Hello @bkent.kenrett ,
This is a known issue and our team is working on this issue. I cannot cannot ensure when this will be fixed but just to let you know our team is already onto this issue.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
mohammed.aliTDPXK
@bkent.kenrett ,
Can you please provide your model as well?
Please attach to this thread if possible or you can directly send me
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
RajkumarIlanchelian
@bkent.kenrett We released a new update 2.0.10446 a couple of hours early that should address this issue. Please update and let us know.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
