F3D files in the tutorials
Message 1 of 10
When I download the F3D files from the tutorial, I don't get any F3D files.
I am in this lesson;
Getting Started for Students / Introduction to 3D Modeling / Lesson 2: Create a new cloud project, upload and save a 3D model.
When I try to upload the file in Fusion 360, there is no F3D file in the folder I downloaded from the lesson.
Replies (9)
Message 2 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
That seems a bit strange - I was able to download it no problem. See the attached file.
Just to check, does your computer automatically unzip files? To be honest, this is what that looks like. If you were to change the .f3d extension, to a .zip extension and unzip that file, your screenshot is what you would see. Perhaps a .f3d file got associated as a .zip in your computer and is being automatically unzipped?
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 10
James,
     The files are downloaded as zipped folders. I have to extract the files from the zip folder. Some work, some don't.
     Note in the screen shot below that there is a Bodies and Components Example zip folder and a Bodies and Components Example file folder. Folders Example.png
When the file folder is opened, there is a an F3d file there.Folders Example 2.png
Other zip folders extract the mess you saw in the OP screen shot.
Message 4 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
This definitely seems specific to something in your environment, it is just tough to tell what. For instance on both Windows and Mac, it works just fine for me on the download.
One quick workaround would be, in file explorer, click the file and select Rename. Delete the .zip extension and put a .f3d and hit OK when prompted if it is okay to change the file format. This should successfully work.
In the meantime can you check the file association for .f3d files per this guide's instruction here?
James Youmatz
Message 5 of 10
James,
     Some zip folders do not come with a .zip or an .f3d file extension. In the case of no file extension, adding .f3d does not change anything.
     In the case where I am not getting the .f3d file in my downloads, changing file extensions or app association does not work because THERE IS NO .F3D FILE IN THE DOWNLOAD.
Message 6 of 10
James,
     I think i found a solution. I will lay it out.
When i save that i get this.
Here is the fix. At the save dialouge, add the .f3d file extension  Example 8.png
Thank you for your help.
Message 7 of 10
I am having the same problem where the f3d file is downloaded as a zip folder. Additionally, some f3d files are saved as f3d files
such as Open_Close_Save, however, trigger_with_mechanics does not. I have followed the method you showed where I rename the folder when prompted to save (by adding .f3d) but this still does not work for me?
James
Message 8 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Edit: Sorry for my original reply, I completely misread your post. Thank you for the tips and solution!
James Youmatz
Message 9 of 10
ahussein0828
Community Visitor
Community Visitor
I was having the same problem until I added .f3d during the save as step.  Now my computer stopped recognizing the file as zip format and sees it as a fusion 360 file.
Message 10 of 10
P.IM
@ James Youmatz, thank you for posting this file! It seems to be missing from at least the first set of tutorials that refer to it.
