Create menu Pattern Bug
daniel_lyall
Mentor Mentor
daniel_lyall
I went to edit the pattern in the timeline in the attached model it is blank you justs need to activate the only part turned on.
The pattern can be changed from the parameters and the numbers are correct in it, I show change the numbers and it works from the parameters just fine, It is just the pattern in the timeline that is dead.
I did the basic restart fusion, restart the computer, online, offline, compute all.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
paul.clauss
Hi @daniel_lyall
Thanks for posting! I received the same behavior that you did in your file and have logged a ticket with development (FUS-37922) to investigate why the pattern seems to be stuck in an odd spot.
I did find that the pattern dialogue appeared correctly if I kept the Extrude6 feature as a new body, and it will also appear correctly if you drag the Extrude6 feature to immediately before Extrude4 in the design timeline.
As I have not seen this behavior occur before and was unable to trigger it in a new file, I would recommend using the working method of editing the pattern through the parameters window that you showed in your screencast or reordering the extrude features in the design timeline. We appreciate you bringing this to our attention - please let me know if you see this occur again!
Paul Clauss
Product Support Specialist
daniel_lyall
Thanks @paul.clauss I will do the reorder of the extrudes thank you for finding a fix for me.
Daniel Lyall
The Big Boss
Mach3 User
