F360 Will not launch
Message 1 of 18
Went to fire up F360 today and got the "Unable to set up Fusion360 for your autodesk account" message.
F360 has been on this machine and working for around 8 months without issue
Checked the Autodesk page, no outages, etc...
Tried absolutely everything I could find in these forums, to resolve it.
Downloaded the Autodesk Automatic Clean Uninstaller, and ran it to completely remove F360.
Re-installed F360, with the same exact result.
Windows 10 machine with all current updates.
Rage.
Replies (17)
Message 2 of 18
rishabh.bisht
Hi @Anonymous ,
Welcome to the Fusion 360 community!
Can you please collect and share the logs?
Rishabh Bisht
Product Owner
Message 3 of 18
Thank you Risabh, I have attached the log files
Message 4 of 18
And here is one more....
Message 5 of 18
Any ideas? Down for another day.....
Message 6 of 18
rishabh.bisht
Hi @Anonymous,
Rishabh Bisht
Product Owner
Message 7 of 18
Hi Rishahb,
No, I am not using a proxy server.
This machine is the only one that I use, for F360. It has had Fusion360 on it, and was working fine for over 8 months...
Now, every time I try to launch F360, I have to log into my autodesk account (which goes smoothly, I complete the two-factor authentication, then I get the "sit tight while we finish setting up F360" message, and then the error message: "Unable to set up Fusion360 for your Autodesk account".
This is unbelievably frustrating.
Message 8 of 18
rishabh.bisht
Are you able to log in to https://myhub.autodesk360.com/ ?
Rishabh Bisht
Product Owner
Message 9 of 18
Yes
Message 10 of 18
rishabh.bisht
There seem to be issues while Fusion is trying to retrieve the hub information..
Can you try below steps and see if it helps:
1. Login to https://login.autodesk360.com/  (which should redirect you https://myhub.autodesk360.com/ ) in a web browser.
2. After you are logged in and can see your projects, Open Fusion 360 client and try to login again there.
Rishabh Bisht
Product Owner
Message 11 of 18
Hello Rishabh,
I tried your suggestion, but it does not work.
I am able to log in to the hub, but, it shows that I have no projects.
(That is scary! I have many projects, stored in the cloud....)
Trying to launch F360 gives the same error message, as before.
Message 12 of 18
rishabh.bisht
Hi @Anonymous , can you try it again? We took some action on our end that should hopefully fix the hub issue.
Rishabh Bisht
Product Owner
Message 13 of 18
Hi Rishabh,
Well, Partial Success...
F360 Launched, and the "create a team" dialog box came up, requiring me to create a team (so, I did).
F360 then opened as normal, however, when I go into Admin projects, none of my prior project files are there....
Message 14 of 18
rishabh.bisht
Hi @Anonymous.,
Can you log out and login again?
After logging in, if you don't see your projects, you can try switching hubs. See below article for reference.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Rishabh Bisht
Product Owner
Message 15 of 18
Hi Rishahb,
OK so here is what I did:
Closed F360, re-started the computer.
Went to my Autodesk Hub page (As far as I know, I have never had a "hub', before).
So when you say "switching hubs" I have no idea what you are talking about.
Anyway, There is still no data there, its empty.
So I tried to launch F360 (because I have to work on something)
Got the message:
So, it would appear that I am right back to where I started.
-Rob
Message 16 of 18
rishabh.bisht
The action we have taken on the server side may take some time to process. Can you please try again after some time?
Sorry for the trouble and thanks a lot for bearing with me.
Rishabh Bisht
Product Owner
Message 17 of 18
Hi Rishabh,
I just tried again, and it seems to be working now. (Hopefully it stays working!) Many thanks for your help,
Rob
Message 18 of 18
rishabh.bisht
Thanks for the confirmation @Anonymous. Glad to help.
Have a great weekend!
Rishabh Bisht
Product Owner
