Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am creating a keyboard case with stand-offs. These posts should all look the same. I started with a sketch and when I extrude, I want to put a constraint on the extrude amount as well as Fillets so all the posts have the same dimensions/operations applied to them. But I realize I'm likely doing something fundamentally wrong.
Here you see two completed studs. I extruded and filleted them individually which isn't ideal. Is there a way to constrain these 3D operations the same way as I did for the sketch shapes? Or could you give some high-level guidance on the approach to use? Just to state the obvious, I need to precisely specify the posts' positions. Thanks for any guidance.
