Extrude/Cut direction is reversed on mirrored part
Message 1 of 8
I have a very simple part which is the mirror of another part. For some reason, when I sketch something on planes parallel to the mirror plane and try to extrude or cut the body it appears to fail. What's actually happening is the preview shows the extrude/cut happening in the correct direction, but the applied extrude/cut is happening in the opposite direction meaning it either extrudes into the body or cut nothing.
I saved the part into an external file and it works fine.
I deleted the mirror and made the part again from a mirror but it's giving me the same issue.
Extruding/cutting on planes perpendicular to the mirrored plane work fine.
I started a brand new design to test the issue and was able to confirm it happening there as well.
Replies (7)
Message 2 of 8
jhackney1972
I cannot replicate your failure when I create a model using your description.  Please attach one of yours that exhibits this problem.
John Hackney, Retired
Message 3 of 8
Component B(mirrored), features Extrude 1 and Extrude 2 both have the issue for me.
Message 4 of 8
g-andresen
I was able to recreate this in a new construction.
@dsouzasujay  can you take care of this?
günther
Message 5 of 8
dsouzasujay
Hi @g-andresen @Anonymous @g-andresen
Thanks for reporting this issue! I agree this is a bug and also annoying, reported asFUS-81578 in internal issue tracking system. Hope we get it resolve sooner.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 6 of 8
This looks like this thread as well. Only punching in the opposite direction does not work either.
Can not punch holes in mirrored componenets
Message 7 of 8
aurimas_karosas
rotating the component by 90degrees cuts the object.
might be a solution for some until the bug is fixed
Message 8 of 8
Does anybody know when the bug will be fixed?
