Extremely slow performance when filleting or lofting
JosiahTullis
JosiahTullis
Hey Fusion team. I love the software, but even on the latest hardware it seems to lag incredibly and crash often when performing simple fillets and lofts. This would be understandable if my geometry was more complex, but often even the simplest of commands seem to cause crashes.
Could part of this have to do with running Fusion 360 on the latest Windows 10 update?
Is there anything I can do to optimize performance or is this just a general stability problem that will improve over time with new Fusion updates?
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @JosiahTullis,
I'm sorry you are experiencing. Smiley Sad
I've searched your CER Report and I'm afraid that this is a known issue which is a crash on Mac (FUS-31990) They are working on it.
However, your problem is on window 10. right?  so I'm sorry I need more information.
Does it happen on all of your models or a specific model?  Would you mind sharing the reproducing steps?
When crashing, were you unable to report CER???
Could you share your diagnostic file and your system information?  this is how to get the file.
Here is how to get the system information.
1. NFO  : msinfo32.exe = system information
A. Launch %windir%\system32\msinfo32.exe
B. Select Save from the File drop down menu (CTRL + S)
C. Please reply with the resulting *.NFO file attached
2. Dignostic file on your pc  : txt file
A. Launch %windir%\system32\dxdiag.exe
B. Select Save All Information
C. Please reply with the resulting *.TXT file attached
Have you installed the graphic driver up to date?
This is how to optimize setting in Fusion 360
This is performance tips for running Fusion 360
I look forward to your reply Heart
Many thanks,
Ahreum. ([email protected])
