Exporting not working properly
allanJKZ4E
871 Visites
9 Réponses
Message 1 sur 10
allanJKZ4E
Since the last update there seems to be an issue where exports requiring cloud translation do not get updated properly and just keep hanging. Might be that the system that pings the server for the file has problems.
The fix that sometimes works is to redo the export and then you get the exported file within a few seconds. The first export will never finish and has to be cancelled when quitting Fusion.
872 Visites
9 Réponses
Replies (9)
Message 2 sur 10
trebor_madoverlord
I am having a similar problem. Exports that require cloud translation usually hang. I have been able to get them to work by quit/restart Fusion, opening a single document, saving a version, and then exporting.
0 J'aime
Message 3 sur 10
allanJKZ4E
Yeah, no comments by the team (great work, team!), or fixes still. Re-exporting helps (but you need to wait for 10-20 seconds for the actual translation to finish in the server). To me it feels that the process that is supposed to ping server for the exported file just crashes.
0 J'aime
Message 4 sur 10
trebor_madoverlord
And of course, as soon as I posted my original reply, exporting started working for me... I really should get in the habit of complaining early and often.
0 J'aime
Message 5 sur 10
allanJKZ4E
Or you might have gotten the export you attempted the last time (if you haven't changed the file since then) 🙂 . Definitely not working for me still.
0 J'aime
Message 6 sur 10
trebor_madoverlord
I've been doing some testing. I am finding that immediately after a quit/restart of Fusion (Mac, M1 Mini), export of projects that require cloud translation (.f3z) appear to work. However, after doing other things, they stop working. Unfortunately, I haven't been able to find a repeatable "do this, exports stop working" case. 😞
0 J'aime
Message 7 sur 10
allanJKZ4E
For me, the first export usually works - doesn't matter if it's directly after opening the file, or after doing modifications and saving + exporting. But if I keep working after that, it pretty much never works without having to re-export to get the file.
0 J'aime
Message 8 sur 10
TheCADWhisperer
@allanJKZ4E @trebor_madoverlord
Export of what file type? Be specific.
0 J'aime
Message 9 sur 10
allanJKZ4E
Anything that requires a cloud translation will hang sooner or later (as said, first export usually works but if you make some changes and try to export again, it will hang and you will get the file only if you make a re-export after waiting for a bit; the hanging export will never finish): .dwg, .fbx, .skp...
0 J'aime
Message 10 sur 10
trebor_madoverlord
As I stated above, after restarting the app, "export of projects that require cloud translation (.f3z) appear to work. However, after doing other things, they stop working."
0 J'aime
