Exporting DXF Scaling Issue
cdamiani
Message 1 of 45
cdamiani
When I export a part from Fusion 360 to a dxf and open it in AutoCad the scale is wrong.  The same thing happens when I open the DXF in Vcarve Pro.  Seems like a Fusion issue.
Replies (44)
Message 21 of 45
cdamiani
The funny thing is I posted this problem over a year ago. I am going from
an AutoCad DXF file to Fusion 360, both Autodesk. Why is this still an
issue?
Message 22 of 45
HughesTooling
issue?
Have you set the units in AutoCAD? A lot of people don't know or do this, especially if they have old template where it was not set or they only ever work in one unit type and they never know the units are set as Unspecified. @TheCADWhisperer  might be able to help with setting units for drawings in AutCAD.
Mark
Mark
Mark Hughes
Owner, Hughes Tooling
Message 23 of 45
LeeWhitemore
My local laser cutters use a software called Lantek to open the file to place on there laser cutter. if i just save as DXF 100mmx100mm square comes out at 2540mmx2540mm way too big if I change to inch then save as DXF it comes out at 39.37mm way too small.
Is there a way to change the output setting for DXF so its in mm and 1:1 scale? im using Fusion 360
I need desperate help I need to make some parts for work we have changed from Solidworks to the paid fusion 360 but now i have this issue and the parts i need laser cutting are building up.
Message 24 of 45
TheCADWhisperer
issue?
What is your setting for -dwgunits in AutoCAD?  (With the preceding - sign as shown.)
Attach example files here and end all doubt.
Message 25 of 45
HughesTooling
This is all down to their software not reading the unit info and just making assumptions and scaling the import wrong. When you save in mm the file is 100mm but their software is reading it as 100 inches and scaling up by 25.4 to 2540mm. Why I have no idea, all the info on units is in the file. Then when you save in inches the size in the DXF will be 3.937 inches and their software is just scaling up by 10 rather than 25.4! As Autodesk created the DXF format their exports are correct, not their fault if others are not following the standard. Even a real cheap and cheerful program like QCad reads and writes DWG and DXF files correctly.
Mark
Mark Hughes
Message 26 of 45
crmmachining
Im also having this same issue, Fusion is showing a 8" circle, When I export and open in autocad its coming in at 20.32
Message 27 of 45
megaplow
Sounds like your document is metric and you are importing as imperial. 8" ~= 20.32cm
Message 28 of 45
LeeWhitemore
I still have this issue, what I have to do is create a drawing from the design scale to 1:1 and create a DXF from that and it works fine.
If I create a DXF from my drawing it comes out a random size.
Message 29 of 45
crmmachining
This was drawn in imperial. Hasnt been a issue in the past, Not sure why its doing it now. I scaled it down in autocad and re saved it. I'll have to try a few other files and see if it does it.
Message 30 of 45
dewagheneire.patrick
Hello there
i got the same thing , i export my object and its multiplicate by 2.54.
My model is already in inch in fusion .
How can i make my export with the right scale ?
thanks for your anser
Message 31 of 45
jhackney1972
You are using the Export command, under the File menu, to create your DXF.  This is OK as long as you realize that the export command uses the Cloud to create the DXF and it works in Centimeters only.  This is why you get the scaling.  You can use it if you like, but the best way is to follow the process outlined in the video.
(view in My Videos)
John Hackney, Retired
Message 32 of 45
ok thanks for your answer , but the thing is that i want to export the 3D model , not the sketch.
Importing sketch will only import 2D
Message 33 of 45
jhackney1972
You did not mention you wanted a 3D DXF.  You will have to use the File, Export and use the Cloud for this conversion.  Once you receive the 3D DXF file from the Cloud, if you want to open it in Fusion 360, you will have to Upload it to a Data Panel folder of your choice.  Once there, you can open it and since it is converted using centimeters, you will have to scale it once it is open.  Use the factor of 0.39370079 (1/2.54) for scaling.
Message 34 of 45
thanks a lot
Message 35 of 45
e_r_griffiths
I have seen this workaround mentioned, but just posting here for visibility. See video.
(view in My Videos)
From a 3D Model:
  • Select the face you want to export as a DXF
  • Create a sketch
  • Instantly select "Finish sketch"
  • Right-click the sketch in the browser you have just created and select "Save As DXF"
This is a workaround that seems to avoid scaling issues at the moment. Apologies for the inconvenience, this is being worked on.
Message 36 of 45
HughesTooling
This is not correct. Fusion will read the units in the DXF so at worst you'll just need to change the document units to inches, no scaling needed. Just did a quick test and for me it opened a 1" cube from a inch document in my default units (mm) and measured 24.5mm. Just changing the document units would give me a 1" cube.
When I open the same DXF in ZW3D it reads the document units in the DXF as CM and automatically scales to mm.
Mark Hughes
Message 37 of 45
HughesTooling
From a 3D Model:
  • Create a sketch
Note. This will only work if you have auto project on active sketch plane enabled. If it's not enabled you'll need to manually project. What catches a lot of new users out is the have auto project enabled then project the surface again and end up with duplicate projections.
Mark
Mark Hughes
Message 38 of 45
e_r_griffiths
Yes, thank you for adding that @HughesTooling.
For new users, I believe auto project geometry on active sketch plane is enabled by default but you can find the option in Preferences > General > Design.
Message 39 of 45
martin.murbach
I cannot believe this is a thing.
In my opinion export as DXF is the only way to get the correct flat pattern of a part. But it gets "multiplied" by a factor 25.4 something.
I Have 30 drawings to process it is such a pain.
I did try the method you show; the dimensions get right however I found that it does not export the bending lines...
Autodesk please fix it ... it seems quite simple to add a scale parameter; isn't it ?
[EDIT] : Nevermind it does not work. As the sketch is only visible in the flattened part and exporting the sketch from there gives the same dimensional issue....
[EDIT2] : Found a workaround - created a completely blank drawing template. Insert the flat pattern on the drawing scale 1-1. Then export sheet as DXF. Painfull but will do.
Message 40 of 45
HughesTooling
What units are you working in? Are they the same in the flat pattern work space and the design workspace? The DXF will be created using the unit set in the flat pattern workspace.
Here's an example where I exported a pattern in inches then in mm and opened in ZW3d. You can see the unit info has been read from the DXF and both imports are the same size. Inches top mm bottom.
Mark Hughes
